Front Coil Spring and Shock:Piston rod lock nut
Old May 5, 2016 | 11:27 PM
G37sGraphite's Avatar
G37sGraphite
I have read that once you remove the spring and shock/strut from your car and after compressing the spring, the nut on on top of the assembly the ( Piston rod lock nut - per the service manual) is a bit of a pain to remove without a impact wrench.
Can one start by loosening this bolt while the assembly is on the car maybe a turn or two? Will this help the ease of removal?
I have read a couple of people did this but I wanted to confirm before I attempted it.
Thanks everyone for your time and any help!
Old May 6, 2016 | 12:34 AM
IIRC it's pretty easy if you have the small wrench that holds the stud in place while you have another wrench to turn that nut. I think it's only torqued to like 28 ft lbs (just going by memory).
Old May 9, 2016 | 11:52 PM
sLADe781's Avatar
sLADe781
What you'll need is an offset wrench:
I got a really cheap but good set at Harbor Freight and it will allow you to hold the piston in place while you turn the bolt.
Old May 10, 2016 | 11:35 AM
slartibartfast's Avatar
slartibartfast
The top of the shaft has two flats on which you apply an open-ended wrench. This holds the shaft while you use the above offset box-end wrench to loosen the nut.
Old May 10, 2016 | 11:41 AM
G37sGraphite
Thanks...will be doing it once my clamshell single action spring compressor is delivered. Gonna head to the store for the offset wrench...
xnick101
May 22, 2016 05:56 PM
Simont122
May 4, 2016 03:53 PM
steven92
NorthEast
May 2, 2016 12:04 PM
gunmetalg35
Apr 29, 2016 12:28 PM
VIVID
Apr 22, 2016 12:40 AM
