Help 3mm wheel spacers. Any one have probelms with wheel support on stock hub?
Old Mar 19, 2016 | 06:12 PM
johnadlertech's Avatar
johnadlertech
I have a 2012 G37xs Coupe, stock 19" with Akebonos. Just got a loaded mint set of the 2012 non-sport X coupe 18" rims to use for winter. Saw a couple of pictures with it working for people so thought I was all good. They do clear but with only 1.25mm clearance. I was bummed, so close it will worry me. Now shopping for a quick fix. 3mm spacers is the thinnest I can find. I don't want to trade my worry about the rims hitting for worrying that the spacers will leave the wheel poorly supported at the hub flange. I really didn't want to use any kind of spacer. And now the most I will deal with is a thin set of pop on hubcentric spacers. I read that up to 5mm thick spacers is ok, but others still complain of issues. 2mm or less spacers would be plenty but cant find any. Thoughts appreciated, thanks.
Attached Thumbnails 3mm wheel spacers.  Any one have probelms with wheel support on stock hub?-img_1225.jpg
Old Mar 19, 2016 | 08:40 PM
jerseytaylor's Avatar
jerseytaylor
A 3mm slip on spacer will not leave it "poorly supported"
You're making this into a bigger deal than it should be.
Put the spacers on and be done with it
Old Mar 19, 2016 | 08:48 PM
johnadlertech
well, I still have to buy them first. Dont want to hit a Chicago pothole and bust a lug stud. Just never used spacers before, prefer to just have the right rims.
Old Mar 20, 2016 | 11:47 AM
You'll be OK w/ that minimal thickness spacer, just be sure you get a full 6 turns on the lug nut (torqued up to 80-85 ft.lbs.) for proper depth into the lug nut.
Old Mar 21, 2016 | 12:08 PM
johnadlertech
ordered a set. Will comment later once installed and run for a bit.
Old Mar 21, 2016 | 12:15 PM
the93owner's Avatar
the93owner
Z1 offers a 2.5mm spacer, but it looks like you've already ordered lol.
Old Aug 2, 2016 | 01:21 PM
johnadlertech
The 3mm worked ok. But I ruined one by not paying attention and putting one of the rears on facing the wrong way. The rear hubs have a small flare that is notched on the spacers. After tightening down the lugs it warped the spacer. My bad. The fronts don't matter.
VQHAY
Mar 13, 2016 03:19 PM
smitty37g
Mar 4, 2016 07:08 AM
supreme
Mar 1, 2016 06:00 PM
xmajd92
Feb 27, 2016 10:00 AM
nethole
Feb 22, 2016 10:42 AM
