Help Coilovers and Preload?
Old Dec 12, 2015 | 01:35 PM
VQCrew's Avatar
VQCrew
Hey guys I got BCs on my sedan and this season I was slammed and I was bottoming out quite frequently just under the oil pan even with maxed out dampening. Can I just increase the preload of the coils to make it harder and compress less or would I have to get new harder springs?? I don't really want to deal with getting new springs.
Old Dec 12, 2015 | 07:52 PM
Should be able to raise them up to a more driver-friendly height and then adjust damping just a bit over halfway to get a decent ride. Just need to keep about a 1/4" of preload on the front and rear dampers. This assumes your shocks aren't blown.
Old Dec 12, 2015 | 07:57 PM
beachbum718's Avatar
beachbum718
Check to seee if they are blown .if not.buy new springs.with a higher k.but you can onlu go up one or two numbers without having the coilover revalved.goodluck.so if they are 8k go up to 10k.makes it stiffer
Old Dec 12, 2015 | 08:55 PM
VQCrew's Avatar
VQCrew
The coilovers are almost brand new only like 5k miles on them. So preloading more isn't going to do anything then? Mine are already 10k/8k. My thinking was that compressing the spring more would make it stiffer?
Old Dec 12, 2015 | 11:06 PM
Those shocks are designed to work at full travel, if you shorten the travel w/ more preload it will shorten the damper life, similar to running lowering springs on OEM dampers. I'd try to just get the height you want to work for your daily driving and then adjust your dampers. I have Megan LPs which are essentially the same as BCs and have my height set to zero fender gap and run just a bit over halfway up on the damper ****, been great for over 3 years now. And this is w/ 1/4" preload F&R. Same spring rates too.
Old Dec 13, 2015 | 10:28 AM
VQCrew's Avatar
VQCrew
Well maybe I misused the term "slammed", I was at zero wheel gap too, maybe just slightly tucking the tops of the tires on 19 inch wheels. So you don't have any issues with the front end hitting/scraping the ground? Awd issues I guess *sigh*...
Old Dec 13, 2015 | 11:07 AM
Ahh, yeah, the AWD w/ it's heavier front and less ground clearance would be more "slam-prone", thought you had a RWD. Just checked my spring specs, they're 12k front/10k rear. Might contact BC and see if a spring rate increase will get you to a better place, also Swift makes many coilover spring sets.
Old Dec 13, 2015 | 11:10 AM
jfisher's Avatar
jfisher
I ran mine up where the seat made contact with the spring and then snugged it just a touch. Like BLnewt said, cranking the spring seat to compress the spring won't help you.
Old Dec 13, 2015 | 01:59 PM
VQCrew's Avatar
VQCrew
Is getting 12k springs going to make a difference though? I have like 1.5 inches of clearance under the front so I don't know. I did send them an email so we'll see what they say. But if they tell me to get stiffer springs, I will need to re-valve,etc and it will cost half the price of the coils then I will have to live with it I guess. Low car problems lol...
Gregor12
Mar 7, 2025 08:48 PM
PongSanity
13
Mar 2, 2016 08:57 AM
Baby Jumpman
Jan 27, 2016 02:40 PM
Baby Jumpman
Dec 13, 2015 08:23 PM
Jharris93
Nov 15, 2015 04:00 PM
