For those of you running Tein Basis- what wheels look decent w/o spacers?
Old Oct 16, 2015 | 06:18 PM
4DRZ's Avatar
4DRZ
I recently installed a set of Tein Basis coilovers on my '13 Sedan and I am planning on running TSW Interlagos 18" or 19" with 245 in front and 275 in the rear. I am hoping this will look ok without spacers. Just wondering what some of you are running and what ride height you have the suspension set/alignment set up. Any pics would be awesome. Thanks!
Old Oct 16, 2015 | 09:44 PM
On your lowered G I'd run a 8.5 +30 to +35 on 245/45/18 or 245/40/19 front
and 10 +45 on 285/40/18 or 285/35/19 rear, if you want 275s in back you can run a 10" +40
Here's my setup on 8.5 +40 w/ 245s and 10" +45 on 285s (was running 295s and still has a couple mm inside the fender) these are 20s but still them same fit at the fender as 18s or 19s w/ the tire sizes I listed
Here's the 295s in back
Old Oct 17, 2015 | 12:59 PM
4DRZ's Avatar
4DRZ
Thanks for the pics, that helps a lot. The car looks good! I did not realize we had quite so much room under these fenders. Are you running Tein Basis too? What height and alignment settings do you have?
Old Oct 17, 2015 | 07:57 PM
No, I'm running Megan LP Street coils and am running 26.25" F & R and camber close to -1.0 F&R.
Thanks for the kind words too
Old Oct 28, 2015 | 10:43 AM
4DRZ's Avatar
4DRZ
Slight change of plans. I really like the WedsSport SA10R Zebra Black Clear in 18x8.5 35mm and 18x9.5 38mm. I would still run 245's up front and 275's out back.
Also considering the Forgestar F14 in 18x9 and 18x10 and I can pick the offset as well as about a zillion different finishes. Leaning toward a polished (almost like chrome) or brushed (raw metal) finish with dark gray or black on the insides of the spokes.
Thoughts?
Old Oct 28, 2015 | 02:34 PM
HoldmyMouse's Avatar
HoldmyMouse
Weds fosho
Old Oct 28, 2015 | 03:47 PM
Originally Posted by HoldmyMouse
Weds fosho
x2, and good offsets for the sedan and the tires you listed.
Old Oct 29, 2015 | 01:31 PM
RxRyanM's Avatar
RxRyanM
Weds x3. So good.
Old Oct 29, 2015 | 03:53 PM
4DRZ's Avatar
4DRZ
Glad you guys like the WedsSport rims as much as I do. Now I just need to save up the money to get them with some sticky tires
Old Nov 1, 2015 | 09:31 PM
takeapieandrun's Avatar
takeapieandrun
I am lowered 1.5-2" and +25 and 8.5 all around if perfectly flush without rubbing issues.
Old Nov 6, 2015 | 06:11 PM
4DRZ's Avatar
4DRZ
what size tires are you running?
Old Nov 6, 2015 | 06:24 PM
9.5 +35 will be similar at the fender and depending on wheel design may allow a more concave face (if you're wanting that).
4DRZ
Nov 7, 2015 08:32 PM
User 122320
Oct 5, 2015 03:03 PM
SheLLz
Sep 24, 2015 08:02 PM
Tapa_Tio
Sep 18, 2015 08:49 PM
