Tein H Tech or H&R springs
Old Dec 27, 2014 | 12:28 AM
PredaKing15's Avatar
PredaKing15
Wanted advice to help make the decision on which set of springs to purchase.
Found the H&Rs on sale for 215 and the Tein H Techs for 190.
Which are the better for overall ride quality and look. Need to make the decision by the 28th before the sale is over.
Any pics of advice would be greatly appreciated.
Old Dec 27, 2014 | 12:31 AM
PredaKing15
Also i plan on going with some 20 inch rims prob this summer.
Old Dec 27, 2014 | 02:33 AM
PredaKing15
Looking at them, I think i am also considering the S techs, Is the ride to hard and is there rubbing and such? Im sure i will need a camber kit
Old Dec 27, 2014 | 08:29 AM
H Techs are a mild drop and more comfort-oriented spring, the H&R and S Techs are deep drop springs w/ a firmer ride. A good compromise would be Eibach, a bit deeper drop than the H Techs but much easier to live with than the deep drop springs. You'll also need a camber/toe kit w/ the deep drop springs and may only need just a rear kit w/ the Eibachs but I still recommend the full kit
Old Dec 28, 2014 | 12:27 AM
PredaKing15
Appreciate it...i was under the assumptions that the H techs were deeper than the Eibach drop...so you would say the eibach over the H&R for sure?
Old Dec 28, 2014 | 09:04 AM
If you want a drop that is easy to live with then for sure the Eibachs, if you want an aggressive drop that you'll have to be careful in your daily drives the H&Rs would be the ticket.
Old Dec 28, 2014 | 10:41 AM
PredaKing15
Appreciate it bro...so what im gathering is both the eibachs and H&Rs are better quality than the teins?
Old Dec 28, 2014 | 12:44 PM
PredaKing15
and u said front and rear camber with the H&Rs? think i will go with them 215 a good deal? from auto anything
Old Dec 28, 2014 | 07:57 PM
Not necessarily better quality, the Eibachs only drop about 1.25" give or take, so it's very easy getting over speed bumps, steep drives, etc. The H&R springs drop a lot more, around 2" or more so speed bumps, ramps, etc can really be a chore to navigate. And the camber kits run about $500 for the complete kit if you do the install so something else to consider. Allowing about $1,000 is reasonable for a drop if you do the install. Springs $250, Camber set $500, alignment $125, tax & shipping, and beer for you and your helper
If you pay for the install add another $200-300
4DRZ
Nov 7, 2015 08:32 PM
sars
Sep 25, 2015 11:21 AM
Tapa_Tio
Sep 18, 2015 08:49 PM
Tapa_Tio
Sep 15, 2015 01:49 AM
Simran Mann
Sep 9, 2015 02:08 AM
