Sway Bar question
Old Jan 7, 2015 | 10:18 PM
Originally Posted by conquistador
I hadn't heard of endlinks breaking on the G37. Now I don't want to install my sway bars that are sitting in the garage!
https://www.myg37.com/forums/brakes-...r-warning.html
https://www.myg37.com/forums/general...n-endlink.html
Now you have.
Old Jan 12, 2015 | 10:40 PM
dgey1's Avatar
dgey1
I have an 09 journey sedan and swapped out eibach sways f & r with aftermarket stock end links. Haven't had any problems. I'm a believer that when you upgrade, you should upgrade everything evenly or you upset the balance of the vehicle... i.e., if you go alot faster then you should be able to stop just as quickly.
Old Jan 26, 2015 | 07:00 PM
Upscale Speed's Avatar
Upscale Speed
Does anyone know if the SPL front end links fit on the X sedan?
I plan on dropping on fortune 500 coilovers w/swifts and extenders, f&r camber kits, hotchkiss f&r sways, cusco STB and I wanted to upgrade the end links too. If anyone can tell me if that will work or not that would be great. I want to bang out my entire suspension all at once.
kavcheung
Jan 22, 2016 02:40 PM
Mattlorentzoe
Sep 14, 2015 07:32 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
