High pitch squeel when braking?
Old Aug 25, 2013 | 06:14 AM
lightlypurified's Avatar
lightlypurified
I recently changed my rotors and brake pads and now i notice my brakes makes a high pitch squeel now when i apply the brakes. I did not purchase any new shimmies so can anybody tell me what the problem is? or is that the problem.
Old Aug 25, 2013 | 06:53 AM
indowanksta88's Avatar
indowanksta88
I am having the same problem! Going to take it to my mechanic in a couple weeks to figure out what it is....
Old Aug 25, 2013 | 09:36 AM
Was grease applied behind the shims and the sliders?
Old Aug 25, 2013 | 10:14 AM
rlo's Avatar
rlo
My experience if they are OEM they just squeal. I cleaned the brakes, applied brake grease, same result. It wasnt until I went aftermarket that the squealing went away.
Old Aug 25, 2013 | 09:22 PM
lightlypurified
I am using. aftermarket slotted and drilled rotors but I am using the s model akebono pads.
Old Aug 25, 2013 | 11:07 PM
lightlypurified
just noticed my 2 front rotors were installed in couner clock wise will try to fix this weekend and see if noise persists.
Old Aug 25, 2013 | 11:21 PM
Rad_Slinger's Avatar
Rad_Slinger
It wouldn't matter which your rotors were installed unless they have directional vanes...and I highly doubt they do. And even if they do, it wouldn't cause the squeeling.
Check to make sure you have the pads installed correctly (inner/outer). Also, did you "bed" your pads properly?
4DRZ
May 29, 2024 09:28 AM
eljoker
Future Models
19
May 30, 2022 11:48 AM
r0cketm0nkey
General Tech Questions
17
Nov 23, 2015 03:34 AM
Rayramg37
Nov 18, 2015 09:06 AM
