Spacers needed with Pro Kit?
Old Aug 15, 2013 | 02:03 AM
roxmysox99's Avatar
roxmysox99
Hey guys,
So I know there are alot of threads talking about the best spacer sizes with the Eibach Pro Kit drop, however every single thread I have looked at refers to a different wheel than I have. I have the stock 2011 G37S rims, Enkei 19'' Sport OEM rims. I've attached the picture of the rim I am referring to. With these rims will I need spacers? I know alot of it is subjective, but what do you guys think? Any one have pictures? Worse come worse, I can order the spacers after I install the springs and before I get my car aligned.
The springs are used so I will get them installed, take it to get an alignment around a week later and get camber kits if needed.
Thanks
rox
Attached Thumbnails Spacers needed with Pro Kit?-kgrhqfhjfifeyj-zkmqbri96tfvrw-60_35.jpg
Old Aug 15, 2013 | 08:51 AM
Originally Posted by roxmysox99
Hey guys,
Thanks
rox
Here you go, these are the previous year coupe 19s but the fit will be the same~
https://www.myg37.com/forums/3665763-post28.html
Old Aug 15, 2013 | 10:56 AM
roxmysox99's Avatar
roxmysox99
Sounds good. I will be getting the H&R ones from FBPARTS. Are you sure 15mm and 20mm is a good combo?
Old Aug 15, 2013 | 12:04 PM
teonguyen's Avatar
teonguyen
I've just received both H&R DRM 15 mm and 20mm spacers today and will install the Eiback PK this weekend. I don't know how the look will be though. Btw Jomer Meer at Fbparts was awesome...
Old Aug 15, 2013 | 02:11 PM
As long as that link I posted is the look you're wanting it's a good combo
Originally Posted by teonguyen
I've just received both H&R DRM 15 mm and 20mm spacers today and will install the Eiback PK this weekend. I don't know how the look will turn though. Btw Jommer Meer at Fbparts was awesome...
Yep, highly recommend Jomer, he got my coilovers to me in 3 business days and was the best price I found by 10%
Old Aug 15, 2013 | 04:58 PM
roxmysox99's Avatar
roxmysox99
DRS or DRM? I will get them installed with my alignment since all my tools will not be accessible? Is there a price difference in the install of the DRMs v the DRSs?
Old Aug 15, 2013 | 07:00 PM
DRMs are a simple DIY bolt on, the DRS involve removing and replacing all the studs, much more labor intensive. No way would I pay to have the bolt on DRM type spacers installed, these are as easy as mounting your wheels to your hubs
Old Aug 15, 2013 | 08:05 PM
roxmysox99's Avatar
roxmysox99
Please post pictures with and without the spacers if possible! You would be a life saver!!
Oh wow. I will most definitely get the DRMs and do the install myself.
Old Aug 15, 2013 | 09:00 PM
Just be sure to torque to 85 ft. lbs. and recheck your torque after 500 miles.
And DO NOT use any locktite on the nuts.
Old Aug 16, 2013 | 01:13 AM
Track Bandit's Avatar
Track Bandit
None of that "RED" stuff right?
Al
Old Aug 16, 2013 | 12:03 PM
roxmysox99's Avatar
roxmysox99
Thank you guys! I will also use anti seize. I will foll
Old Aug 16, 2013 | 12:04 PM
roxmysox99's Avatar
roxmysox99
Thank you guys! I will also use anti seize. I will follow the online guides on here. Drop, spacers, alignment, retorque.
Old Aug 19, 2013 | 05:34 PM
teonguyen's Avatar
teonguyen
[QUOTE=roxmysox99;3666800]Please post pictures with and without the spacers if possible! You would be a life saver!!
I dont have pic that without spacers cause i put the spacers on right after I had the spring installed.. Sorry for the crappy iphone pic . 4 hours after drop 20mm F and 15 mm R..Btw he is my friend trying to measure the gap...
Go to post #3 I think this drop is without spacer.
https://www.myg37.com/forums/brakes-...-question.html
G37xhibeet
Nov 15, 2016 09:29 AM
Intake
Dec 25, 2015 09:38 PM
BANNISTER
Dec 10, 2015 04:14 PM
i heart ricers
12
Dec 9, 2015 04:15 AM
beachbum718
Aug 16, 2015 10:35 PM
