How high with Stances???
Old Oct 15, 2012 | 12:42 AM
SkylineAWD's Avatar
SkylineAWD
Question How high with Stances???
I have my Stance GR+ coilovers on the car and recently switched my 305 Invos in the rear for 305 Pilot Sports. What Michelin nor Discount Tire told me is the Michelin's have a thicker and wider sidewall, so now I'm having rubbing issues.
My question is does anyone know how long the threaded tube in the stances are? I need to raise the rear, which I have 1/2 inch already, but need to go another 1/2 inch I believe to avoid tire to fender strikes. I just want to make sure I don't thread to much out and cause any problems.
Shawn
Old Oct 15, 2012 | 06:01 PM
SkylineAWD's Avatar
SkylineAWD
Ok I did get a little clarification today after talking with Stance. The threaded tube is supposed to be 22 CM in length, which comes out to roughly 8.6 inches. The current length showing is around 9 inches, so I must have a longer tube in mine.
Scott Wortman at Stance was very helpful and stated that I could have a longer tube and that he just measured one of the tubes they had there. They do offer a longer tube in case anyone runs into the problem of needing one. I will be checking the suspension tomorrow and unthread the lower mount completely to see exactly how long it is.
Scott did say that I could adjust the spring pre-load perch up about half an inch and it shouldn't affect the static spring rate too much.
Just thought I would give everyone a followup. However, if anyone has the information that would greatly helpful.
Shawn
37
Oct 17, 2020 11:12 AM
ajosowiecky
Sep 30, 2015 12:15 PM
Slapshot1
Sep 27, 2015 08:40 AM
