offset for sedan in rear question? 20x10 +35
okay i got my wheels today. They were not the same offsets as avertised. dam fleabay sellers BS.
**PICTURES ADDED**
http://i45.tinypic.com/2qjek8z.jpg
http://i49.tinypic.com/262sbxv.jpg
front are fine 20x8.5 +32 cool
rears are 20x10 +35 not so cool. They poked out when i had it jacked up.
i wanted to run 255/35/20 in front and 285/30/20 rear.
stock ride hieght for now,will be doing eibach.
My question is will they camber in with a tire mounted with the cars weight? stock ride hieght and will the tires rub?
CAN i camber in the stock suspension?
**PICTURES ADDED**
ive never owned a wheel set up like this..
I havent paid for the tires just yet,i just want to double check because once you mount. You own it..
i get what you guys are saying,but i would think it would just drop down and not stick out that much. The offset is my worries.
Put a block under the wheel and drop the car to put some weight on it so that it lifts. First time I put my 20x10.5 on in the rear I had nearly the same look you've got there and was a little scared it'd rub still. Set the car down and it tucked just fine.
I just did the block trick it closed the gap,but not all the way.
is that normal for the offset?
Maybe with the tire it will close more idk.
i was gonna mount a tire but, dam firestone is slower than s-hit with shipping..
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
alright im trusting you guys...
just waiting on the tires and gonna mount them.
There nothing special there lorenzo wl26 matte black with meachine finish
got them real cheap300 shipped
Without lowering the car, the rim of the wheel will stick out just as you see it on the blocks. You mentioned that you will be lowering the car with Eibachs in the future. Once you lower the car the natural camber that will be created will tuck the rim of the wheels in further.
To give you an idea of something similar, here is another member's car. He is running 20x10.5 with a 35 offset in the rear. He is lowered with, I believe, 1.6 degrees of camber in the rear. Take note, his wheels are 20x10.5 as opposed to your 20x10s.
