will they fit?
will they fit?
On my 2012 G37 6mt coupe I have avant garde m310
19x9.5 +40
dropped on kw v3's
will a 295/30/19 fit in the rear without rubbing?
also on the front I have 245/40/19 will the 30-40 difference cause any negative effects (currently running 275/35/19 on the rear)
19x9.5 +40
dropped on kw v3's
What's the reason for wanting to go that wide? Do you have over 400whp? I wouldn't recommend it if not. Probaly gonna ride bad and not look right. I just put on a 255/35 on a 10.5 and 235/35 on a 9.5, its a mild stretch. I would just stick with the size you have now since you already have a wide tire on that size rim and offset.
^^ reason is just for more grip, I go to the track pretty often, and I would like a little more rear end grip. Plus I like wide tires? lol The 275 is good but still seems a little skinny for me.
Just go with a 275. If you run that much of a difference between your front and rear tires its going to affect your handling. Plus our cars dont need a 295. A 275 is more than enough. If you want more grip go with a track tire or michelin pilot sports.
^^ thank you for the info sir
yeah I figured as much, but I do see a lot of mustangs run the 295 on a 9.5, doesn't seem to cup too bad, ill prob stick with the 275's for now and get an 11 and then go for it
Ordered some nito nt05's so should be somewhat stickier for what I am using now. Thanks again for the info!
there was a porsche article somewhere saying how a little pinch is good on the track. honestly, i think you might rub a TINY bit (nothing shaving the brackets cant fix). im on 19x10 +30 with a 285/35/19 and i rubbed until i got it shaved down a bit.
19x9.5 +40 ~> 19x10 +33.65 -5 (for the 10mm wider tires) ~> 19x10 +28.65 so i anticipate rubbing before you shave the brackets. again, this is very much pending on how low you are (~27"from middle fender to floor, dont remember), how your damping is adjusted (8/10 clicks but im on a different set of coils), and your neg camber (im -2).
however, what concerns me is the 30 profile & your speedo accuracy (since you said you track). look at a previous thread i made about tire sizes and follow some tips i suggested for designing your tire setup.
correction, go the track with hankook rs3 or bridgestone re11s.
37
Oct 17, 2020 11:12 AM
ck1109
Oct 15, 2015 11:06 PM
