Modme's OEM Bracing Project
Old Mar 23, 2019 | 11:47 AM
  #91
The Pope's Avatar
The Pope
Originally Posted by The Pope
See post #2 & #3 of this thread.
Instead of sourcing the frame component like the OP in post #2, I'm fabricating one.
Instead of fabricating the Cross Brace/Damper components (like post #3), I purchased the NISMO components.
Hopefully that will answer your question, but if not, you'll just have to wait for the photos.
Ok.... I have Rev 1 of the bracket now, but it's going to be another week or two before I can do the install. So to help some of you to better understand what I'm doing, here are some photos of the Rear 370Z NISMO Damper w/Forward Braces and my Rev 1 Bracket all bolted together.
Old Mar 25, 2019 | 07:34 AM
  #92
The Pope's Avatar
The Pope
Well.... I was able to do the install!!!
Here's the original Cross Brace (top) that was removed and the NISMO Cross Brace/Damper/Angle Braces.
Here's my Offset Bracket mounted where the original Cross Brace mounts.
I used the original bolts from the OEM Cross Bracket to mount it to the body.
I made accommodations in my Offset Bracket to attach the wiring harness, as the original harness mounting points were covered by my bracket.
Here's the Cross Bracket & Damper in place (as seen from right rear wheel area).
I use M8x60 Bolts, Finder Washers & Nyloc Nuts. The reason for the M8s is the Forward Angle Braces will not accept anything larger and by bracket was designed with the holes (slots) based on the size of the holes in the NISMO Cross Brace.
You can also see the Forward Braces going over the exhaust and under the Diff.
Here's the forward right side mount for the Angle Brackets. The bracket that it mounts to already has M8x1.25 Nuts welded in from the factory. I chased the threads to clean them out and use M8x50 bolts.
Old Mar 25, 2019 | 02:19 PM
  #93
The Pope's Avatar
The Pope
Here's some photos of the bracket prior to wielding....
Old Mar 25, 2019 | 02:21 PM
  #94
I don't know squat about this kind of fabrication, but damn if that doesn't look like professional work.
Old Apr 3, 2020 | 03:51 PM
  #95
projectpanda13's Avatar
projectpanda13
Originally Posted by Modme
Anyone know if this bracket is spot welded or completely welded? Hoping spot welded so I can drill it out and reweld it.
Old Apr 3, 2020 | 06:50 PM
  #96
The Pope's Avatar
The Pope
By the images in the 2nd post, it "appears" to be spot welded.
Old Jun 2, 2020 | 04:28 PM
  #97
xxg00w0's Avatar
xxg00w0
Update: the Vert Cradle Braces were a direct bolt-on for the Sedan. Zero issues, perfect fitment. Torqued to spec.
Hardware needed in total:
  • Two of the longer bolts, with matching serrated flange nuts.
  • Two of the shorter bolts, no nuts.
I'ven been trying to install the Cradle Braces for my coupe but can't seem to remove these nuts. what's the torque spec on these nuts?
Old Jun 2, 2020 | 04:34 PM
  #98
I have absolutely no idea. However, torque specs are always indicated in the FSM diagrams. Find this in the FSM, and you'll find your answer.
Old Jun 3, 2020 | 11:18 AM
  #99
BULL's Avatar
BULL
Moderador
1 million foot pounds of torque. Have fun with that.
All G/Z suspension bolts are torqued to scream due it being a "sports car" despite any trim.
I learned that with a couple of them. 1/2 bar with a cheater pipe will be your friend.
Old Apr 8, 2023 | 05:01 PM
  #100
thescreensavers's Avatar
thescreensavers
Phase 1: Front Crossmember Brace
This pair of braces connect the front engine cradle to the chassis of the car.
Parts you need:
544C4-1EA0A Right brace
544C5-1EA0A Left brace
081B7-0455M x2 bolts
11298-CA015 x2 bolts
You also need 2 M10x1.25 nuts. I couldnt find a part number for this.
Purchased a set on Ebay and got these installed.
081B7-0455M is a thru bolt and can be subbed for any Class 10 M10 50mm Long Bolt. I used what I could find at Ace hardware, an M10x1.5 50mm Long Bolt with 2x Washers and Class 10 M10x1.5 Nut(per side). For the bracket side an oversized OD washer would be beneficial but not required.
11298-CA015 is an M10x1.25 bolt, I used an extra trans mount bolts that I had leftover from the Junkyard that fit. But a bolt that is at least 25mm long is good.30mm will work as well as the cavity is pretty deep.
You can get all the hardware for <$10.
Thanks Modme for this info!
Old Jul 31, 2024 | 01:07 PM
  #101
Originally Posted by Zack342
Are the part numbers listed in the original post the correct ones for the bolts?
9 years ago I wrote that I bought the hardware listed at the top of the thread, so yes.
All these years later, and I'm still wondering why the RWD G doesn't have this bracing, when the AWD (and Vert) does.
Whatever the reason, it's a straight-forward, bolt-on mod. Have at it, Zack.
Old Jul 31, 2024 | 01:51 PM
  #102
Zack342's Avatar
Zack342
Sorry for commenting, i ended up reading down further and saw you mentioned it was correct and deleted my post. wish i bought these back then. The brackets themselves have gone up a lot in cost.
Old Aug 14, 2024 | 01:16 PM
  #103
Zack342's Avatar
Zack342
Not to be the proverbial "dead horse" but looks like these come on the 370Zs, sadly I should have also done this 10 years ago as they are no $120 each for the brace.
Old Aug 14, 2024 | 01:22 PM
  #104
thescreensavers
I bought them used on eBay and sprayed them, far cheaper. I think I paid $60 for both and they made a noticeable difference.
Old Sep 6, 2024 | 10:53 AM
  #105
projectpanda13
I didn't realize how much different the coupe and sedan rear was until someone tried to install the 370z nismo rear chassis damper on a sedan. The examples in this thread were on a sedan and the bracket used only works on a sedan.
Credits to Ron Chinner on facebook. He machined the bracket for the sedan and made it work on his car. I bought the same bracket and hopes to install it soon.
Picture credit to him also.
