Help with finding new rotors and pads
Old Apr 26, 2012 | 10:54 PM
TheAmazingNik's Avatar
TheAmazingNik
I need new rotors and pads because mine are all warped and not so responsive anymore (probably needs to be bled) but instead of just getting that OEM look I want a slotted brake rotor and if that isn't possible drilled will due. (front/back)
For those. I need pads and I wanted input for good ones from my fellow G owners. I have the journey so NO big brake kit. Thanks for the help.
Old Apr 27, 2012 | 01:43 PM
Fezzik's Avatar
Fezzik
This may be the time to think about upgrading to the big brake kit possibly.
If not, stoptech are good rotors and Hawk HPS pads to go with them will work out well.
Old Apr 27, 2012 | 02:13 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Coupe or sedan? And is it the Journey Sport or just Journey?
Old Apr 27, 2012 | 06:10 PM
TheAmazingNik
It's a sedan and journey, no big brakes.
Old Apr 27, 2012 | 08:10 PM
joo030879's Avatar
joo030879
I think best rotors and pads for our G37 are from EBC.
100% Made in UK so good quality. Yet reasonably priced.
Also they are much better quality, finish, and cheaper compared to Made in China's Centric/Stoptech.
Other option would be DBA but they are extreamly expensive. So I don't think we should put too much money on replacement parts like pads and rotors.
EBC Rotors are $300 - $500 for entire set for Sport Model. Should be much less for Non-Sport.
Dimpled and slotted
Their Ultimax Rotors
Stock Replacements
EBC carry excellent line up of pads to choose from.
Blues and Yellow for racing
Ultimax, Green and Red for Street Driving.
I use Red because they maintain my wheels clean.
Old Apr 27, 2012 | 10:58 PM
dk85's Avatar
dk85
Stollen rotors, hawk pads, project mu pads. You can get zinc coated rotors to prevent rusting if you like. Not too good on responsiveness I heard.
Old Apr 27, 2012 | 11:38 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
Lemme know what you need, I'll hook you up w/ rotors and pads
Old Apr 30, 2012 | 04:35 PM
Neal@tirerack
Unfortunately we don't have anything front rotor wise, but Hawk HPS pads for aggressive street driving work well.
Old Apr 30, 2012 | 05:17 PM
joo030879's Avatar
joo030879
I would NOT recommend Hawk....
Our recommended Pad Length x width x thickness
4.85 X 2.165 X 0.433
Hawk Pads come slightly bigger and thicker
5.01 X 2.98 X 0.626
With my experience. The slightly bigger is not a big deal. However the thickness of the pad is a major problem. Making piston rubber boots closer to the friction area between pads and the rotor. Prone to overheat the boots and later melt and rip the rubber boots into pieces.
Probably no big deal if you always gently brake. However if you are one of those that brake at last moment. Stay away from Hawk.
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
T_Buckets_223
Sep 8, 2015 09:49 PM
photocat
Sep 3, 2015 01:46 PM
ZachThomas
Sep 3, 2015 01:40 PM
