Help! Grinding Noise!
Old 04-16-2012, 12:46 PM
OB G
OB G's Avatar
Hi folks, hoping you can help me diagnose a strange noise I've been dealing with.
Recently I've had a grinding noise (sounds almost like metal on metal) coming from the front passenger side of my car.
-I have ~15,000 miles.
-Sound is only apparent when I turn my wheel during low speeds, at <10mph.
-If I jack the car up, I can't replicate the noise. So noise only happens when the front suspension is loaded.
-Checked my coils, sways, and upper a-arm to make sure everything was torqued down right. It all looks good.
Dealership doesn't seem to want to deal with it since I have all aftermarket suspension parts and that's what they claim my issue to be. Can anyone help shed some light onto this?
Thanks!!
Old 04-16-2012, 08:48 PM
Lucster
Lucster's Avatar
Thats really weird i actually expirienced the same sound today doing a U-turn a really slow one hm.. i took it to the dealership they couldnt replicate the noise either.
Old 04-16-2012, 10:36 PM
OB G
OB G's Avatar
Bump...any insight on this guys?
Old 04-16-2012, 11:03 PM
JOHNNYG37S2008
JOHNNYG37S2008's Avatar
I had Metal on Metal and it was my wheel bearing. They replaced it.
Old 04-17-2012, 12:49 PM
JOHNNYG37S2008
hope i helped
Old 04-17-2012, 01:30 PM
Xcalibur
Xcalibur's Avatar
Try jacking up the car on the passenger side front to get the wheel off ground and then grab the tire/wheel and see if you can shake or move it a bit. If you have play it could be an a-arm issue if I'm correct. How low are you? And What Camber?
Old 07-09-2017, 09:08 AM
Jen37S
Jen37S's Avatar
Figured mine out
I had a loud grinding noise when turning left slowly like to park. I actually dropped it off at my local Infiniti scared of what they would find. To my relief, I was only charged me $55 to fix a bent dust shield. Since I looked through the internet trying to figure it out, figured I would post about mine..
fuzzed
08-21-2020 09:35 AM
Rybitron
11-18-2015 03:11 PM
si_driver
10-01-2015 09:53 AM
MrRiv
09-29-2015 04:59 PM
Slapshot1
09-27-2015 08:40 AM
Quick Reply: Help! Grinding Noise!
