Resurface rotors or new rotors
Old Jun 13, 2011 | 01:46 PM
ucla bruin's Avatar
ucla bruin
Need rotors resurfaced soon. Have about 4mm of pads left so I may want to get both done at the same time. Not sure if I should just have the rotors resurfaced or get new ones? Pros, cons? What would the approximate cost of each option?
Anyone know where to go for resurfacing in So Cal?
__________________
Old Jun 17, 2011 | 12:25 PM
37drift's Avatar
37drift
brought mine to a reputable shop in NY to have them resurfaced. the owner nearly laughed me out the door. i guess turning rotors is becoming ancient practice because of the availability and pricing of decent aftermarket replacement.
he ended up doing it, but wasn't happy. $15 per corner. i feel like i should have just put that money toward a new set.
Old Jun 17, 2011 | 12:40 PM
Ken's Avatar
Ken
^Nothing wrong with resurfacing rotors. It's still commonly done. If you can still get decent use out of rotors that get resurfaced, then do it because it helps to save money.
Old Jun 17, 2011 | 12:56 PM
djshortsleeve's Avatar
djshortsleeve
I have my g37 in the shop today (Infiniti) because I needed the wood replaced under warranty, but I also had them do the 30k service and brakes. They offered to resurface the rotors (surprisingly).
Old Jun 17, 2011 | 01:09 PM
A_Palaroan's Avatar
A_Palaroan
Hey how many miles do you have on your car? I have 45,000 and i have a feeling i might need new pads and a resurfacing myself. I was thinking of other options but not sure. let us know what you decide to do. oh and another thing whats the average life for our rotors? i know driving habits are a big part but i would like to know a general range. thanks
Old Jun 17, 2011 | 02:12 PM
djshortsleeve
I had about 32k when I needed new pads and resurface rotors.
Old Jun 17, 2011 | 02:40 PM
ucla bruin's Avatar
ucla bruin
I'm at 63k and have been told from visual inspection by the dealership that I still have 4mm of pad left. Going to check it myself this weekend and bleed the brakes as well.
__________________
Old Jul 12, 2011 | 09:06 PM
Fresh Mobile's Avatar
Fresh Mobile
Well I'm in the same situation with 5mm of pads remaining. I called up my dealer and they said its $350 to resurface front rotors and that price includes brake pads and labor. So thats $700 total with rear
Dearler said its $140 for new rotors and front pads are $107 and rear are same for rotors and pads are $97. I might as well go with new rotors...didn't ask the total for labor and parts for new rotors though...i'll do that tomorrow.
Should i just get aftermarket slotted rotors with pads combo?
Any recommendations?
I actually resurface my rotors april 2010 and wondering if i should just get the brake pads only?? Its crazy you have to resurface your rotors or get new ones when you change you brakes pads....and dish out 7 bills grrrr
Old Jul 12, 2011 | 09:54 PM
QuickSilver08's Avatar
QuickSilver08
I've got 220k miles on my truck. Put I can't tell you how many sets of pads on there. Never once had the rotors turned. Never once had an issue with the brakes. No squealing or warping. Unless your rotors are grooved I would just slap a new set of pads on it and call it good. Not saying that resurfacing is a bad idea, it's a good one, but I wouldn't sweat over it to much. O'reilly's does rotors for $10/piece last I checked.
As for the rears, I doubt they are worn that much at all since the fronts do most of the work. I'd check em and see what they look like but more than likely they are fine.
Old Jul 12, 2011 | 10:08 PM
beerme986's Avatar
beerme986
i only change my rotors if they are warped ..and 700 for new rotors and pads is crazy high (but what else would you expect from a stealership). if you cant DIY, find a shop that will do it for half price. man if I could charge 700 for all that, I would quit my job and do rotors/pads all day long
Old Jul 12, 2011 | 10:24 PM
Fresh Mobile
I'll definitely inspect front and rear rotors myselft and take them to a local shop to resurface if need be. If not i'll just get some new pads and slap it on
I don't have tools and time for the DIY. Hopefully i'll find a shop near by to fix/clean rotors if needed.
Thanks for the input fellas...appreciate it.
Old Jul 13, 2011 | 05:14 PM
Fresh Mobile
New front rotors/pads and labor is $550. Rotors=$140 each, Pads = $90 labor = $180 .
I called up a different stealership and they said the rotors are $110 each. Pads $100 front and $78 rear but labor is the same $180 for front and $180 for back. Total $978 for new parts. $590 to resurface/pads and labor for front and back at same dearler. Infiniti of Manhattan want $1100 for new front and rear rotors/pads and labor OMFG!!!!! I called them out of curiousity.
Old Jul 13, 2011 | 06:43 PM
RYs06MT's Avatar
RYs06MT
Put Alex's emblems on your car and maybe a BMW dealership will do it for free! The joys of free maintenance.
Old Jul 16, 2011 | 07:35 PM
Fresh Mobile
So did some checking around and here are my options....
#1 Dealer will charge $540 to resurface rotors supply brake pads and labor? Upside towards price is it's from the dealer who know what to do and OE parts.
#2 Firestone (New Tires, Auto Repair & Maintenance | Firestone Complete Auto Care) will charge me $400 to resurface rotors, supply brake pads(wagner) and installation. Might conside this opition. But not sure about wagner pads???
#3 Last option i buy the hawks pads for $158/ or Akebono ProACT Cermic $150 and local shop resurface rotors and install brakes for $438 hawk/$430 Akebono ...$280 to resurface rotors and brake installation. Don't know sh*t about local shop and don't trust any shop that easily. I rather pay the extra and have the dealer do it. So i'll be at ease so this option might not be considered.
Last resort...
I did resurface the rotors april/2010 so if i have to get new rotors then I'll just buy the SP Performance Cross drilled and slotted rotors or SP Diamond Slotted rotors and Hawk Cermic and have local shop install both for $120 and call it a day.
I'll have firestone do a free brake inspection on sunday since i have a coupon :0) and see if resurfacing is possible. Have appointment with dealer for Monday and firestone you can do walk ins.
ANMVQ
Dec 8, 2016 04:55 PM
Stevolkz33
May 28, 2016 02:36 AM
cyberone28
Sep 18, 2015 12:28 AM
T_Buckets_223
Sep 8, 2015 09:49 PM
photocat
Sep 3, 2015 01:46 PM
