Whats the official word - Front camber kit?? Yay or Nay?? Any Flaws??
NextLevel Performance
This is for ANY OF YOU that have slammed cars and have had an allignment. Do you advise TO have, or NOT TO have a front camber kit? If yes/no, why? and do you have the revised front camber arms?
***Post up your allignment specs!!!! How's your tire wear? Mileage?
***ANYONE WITH a front camber kit, do you see any FLAW in having one?? Kit hits the front fender?
***Anyone WITHOUT a front kit camber kit, do you not have one because of the $cost$, or because you don't need to be within spec????
Im on Eibachs, not slammed, have both front and rear.
Specs? They are dead on factory specs.
They don't hit the fender.
I have 9K, and tires will make it to 20K flat across.
Does one realized how much negative camber comes in when steering and your caster is at 5 degrees?? A lot!! So theres no need to go more negative than specs.
Im dropped on Eibachs in the front and Tanabes in the rear. I'm also running 20mm spacers all around on stock rims with no rubbing issues.
I herd that you dont need camber kits with Eibachs but I don't think thats the case with me. I tired to save some money and see how bad the tire wear would be. I've gotten 3 alignments done since my drop and my tire wear is horrible, especially in the front. My camber is slightly out of recommended specs and my toe is within. Most of my driving is on the freeway.
Lesson learned the hard way
. Saving up for some camber kits.
im on eibachs as well and have slight front tire wear only without a camber kit. maybe 13-15k miles on them. I just took the tires off the rim and swapped sides lol. good to go for another 15K
yeah these tires are directional tires so you have to take them off the rims and swap the tires and then remount. if that makes sense. Front for front rear for rear. for me its free but most people do not have the tools to do it themsleves and take them to a discount tire or such.
Thanks for the feedback guys. It seems as all the guys that posted in this thread all have springs with relatively conservative drops, and even with yoru guys' allignments you still have atleast SOME uneven tirewear.
I just received my F & R camber kits yesterday, so I'll be installing them. I'll also be getting a before and after printout of the allignment chart. As I've stated in a few other threads, I'll be trying to make a sticky on all of this and the specs for everyone to see what a full camber kit accounts for.
is the normal tire wear for eibachs?
I didnt realize how bad my tires were until i just took that picture. how much longer do you think I could run these tires because the insides still have a lot of tread on them. The two front tires were swapped yesterday. Times are tough and moneys a bit tight to spend on tires.
holy sh*t^^ your tires are as bad as mine and I'm slammed on KW's!!??? I'm actually suprised a shop woudl actually swap the tires for you? Where did you go?
I called tires plus and they wouldn't even swap them for me. They said most shops won't swap them ANY part of the tire is under a certain tread depth because of being a liability, and the very edge of those is SHOT.
Did you get an allignment too? It seems like its gotta be off if its just ont he edge like that and you're only on eibachs. you mayyyy want to start saving for camber kits my friend :-) I just ordered mine from TMmotorsports on here. Nick's def the sh*t!
Also...the tires you had swapped are actually pretty dangerous to run. you literally have NO tread left ont he outter wheel, and what happens if you hit ANYthing sharp to puncture the tire? can say goodbye to your mint wheel...
