Where to get SPC Camber kit installed near LA?
Old Oct 13, 2010 | 02:49 PM
Gthirty7_S's Avatar
Gthirty7_S
Hey guys,
I recently purchased an 08 G37S coupe. It is already lowered on Eibach springs and the owner included the front and rear SPC camber kits, not installed yet.
Anyone know of a good place that does camber installs and alignments near Los Angeles. I live in Marina Del Rey. Also, how much can I expect to pay? Midas quotes me over $500 just to install the 2 kits. Thanks!!!
Old Oct 13, 2010 | 05:20 PM
Team STILLEN's Avatar
Team STILLEN
We can handle the installation and alignment.. Will PM a price..
Old Oct 13, 2010 | 05:39 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Damn $500 bucks is insane. Hit up Lou at amplified motorsport 705 Monterey Pass Rd. Monterey Park CA. Ph# 323-881-0882. Call em up for pricing man.
Old Oct 13, 2010 | 05:57 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Either one of the two shops mentioned above will install them and install them right
Good luck!
Old Oct 13, 2010 | 06:50 PM
Gthirty7_S's Avatar
Gthirty7_S
Thanks for the quick responses guys! Josh, I'll give you a call soon so we can set something up.
Also, I think I remember reading about people having problems with something rubbing on the front camber kit. I'm having trouble finding it via the search function. Is this something I should worry about, or should I get the fronts installed too since I already have them?
Old Oct 13, 2010 | 07:24 PM
Team STILLEN
Most guys haven't needed to utilize the front camber kit with Eibach springs, there is enough adjustment in the car.
The rears, absolutely will need the extra adjustment from the SPC kit. You could save some $$ and get away with just the rears.
Coilovers with an aggressive stance would need help for the front.
Old Oct 13, 2010 | 10:33 PM
TVPostSound's Avatar
TVPostSound
Really?? Where??
There is NO camber adjustment on the front wheels.
I was at -1.6 on both fronts after Eibachs.
Yes the toe can be adjusted to spec, and yes you will respond by saying -1.6 camber wont wear tires.
But no one drives twisties enough to justify excessive negative camber.
Bad advise, get the arms, and bring it back to -6 where it SHOULD be.
Im canceling my splitter order!!
Old Oct 13, 2010 | 10:36 PM
Team STILLEN
Unfortunately each car is different.. and he has them, we'd be happy to install him. Any goals or concerns are always discussed with the service manager before work begins.
Why in the world would that have anything to do with a splitter?
Old Oct 13, 2010 | 10:38 PM
TVPostSound
That was with the first generation arms, where it would hit the underside of the fender.
The new ones are fine.
On another note, if replacing with new front control arms, I would advise getting new ball joint pinch bolts, and properly torque them, $10 worth of insurance.
In my past careers,
I was an ASE certified auto tech for 13 years, and an A&P licensed helicopter tech for 2.
Old Oct 13, 2010 | 11:18 PM
B L U E S L A T E's Avatar
B L U E S L A T E
Amplified Motorsport will meet and exceed your needs.
Old Oct 14, 2010 | 02:27 AM
Gthirty7_S's Avatar
Gthirty7_S
In my past careers,
Thanks for the heads up. I think I'll end up doing both the front and rear camber kits. I mean... why not since I already have them both in my trunk? Also, I'll be sure to get those bolts too.
Old Oct 14, 2010 | 11:06 AM
TVPostSound
When you have them installed, go here for an alignment:
Temple City Auto Repair, 4 Wheel Digital Alignment, Brakes, Suspension, Tires, 91780, Falken, Yokohama, Toyo, Kumho, Hankook, Goodyear, Michelin, BFGoodrich, Bridgestone, Pirelli, Cooper, Nitto, Tires, Alignment, Brakes, Rosemead, CA 91770, Arcadia,
aliiin
Apr 27, 2018 10:37 PM
GFTW
Nov 11, 2015 02:56 PM
Ipp391
Aug 28, 2015 09:27 AM
kyro840
Aug 9, 2015 01:38 PM
