Does dropping your car affect suspension?
I would think that the engineers who designed the car have made the car to the exact specifications that would optimize handling and suspension. Does dropping your car negatively impact this? I'm not a modder-type, but I am considering dropping it for the looks. But if it will hinder performance, I won't. What's the deal with dropping?
It does have alignment issues (ie. caster, camber, toe-in&out). it will also affect your shocks if you only change the springs. I have mine dropped for looks as well.
If you drop the car doing it the right way, you will be fine. This means: True coilover kit (~$1700), camber kits for front & rear (~400) but the fronts arent released yet, and then installation & alignment (200ish.)
If you want to do it the cheap way: Set of springs ($200) and DIY installation (highly not recommended as it is dangerous) so $200 for installation, and then an Alignment is a must. Eventually though, since your springs arent made for the shocks, the shocks will give out.
I got my alignment at firestone, $129/lifetime alignments.
Having a drop will affect ride quality, so look at spring rates and do your research. Also look up drop height, some springs drop more than others.
Either way dude, a drop changes the look of the car (SAM! I hope you read this!!! you need this NOW!) and i definitely say you should do it.
lol you people just can't leave me and Eva alone eh?
Its too much of a headache worrying about all the alignment etc.. it wear down your dampers faster and you'll scrape the **** out of your car (H&R and Eibachs Pro especially).. you should be happy enough with the S suspension & height
(I'm getting banned tonight lol)
Dropping a car correctly actually enhances most every aspect of performance. It's not that way from the factory for a variety of reasons, mostly cost and comfort. It usually comes at some sacrifice to ride and comfort, but will greatly improve cornering, body roll, and straight line stability.
Springs are fine for a drop so along as you 1) get the right springs for your application from a reputable manufacturer, 2) don't drop it so low that it throws off all your suspension geometry, 3) don't get a spring so stiff that it causes very accelerated wear on you struts. That being said, coilovers are a much better alternative but much more expensive as well. $2K+ for parts and installation.
If you are mostly interested in dropping it to make it look good, consider Tanabe NF or Eibach Pro Kit springs as they are a mild drop that will still allow you to probably get your alignment back in spec. If not you'll need to add a rear camber adjustment kit to get the back inline. Total cost of about $400 plus labor of $200 to $400 for the springs, camber kit, and alignment.
hilarious....
Wow, that is dangerously genius.
__________________
__________________
Sway_NV
Aug 15, 2015 09:36 PM
MeatySock
Aug 14, 2015 08:25 AM
