View Poll Results: How did you install your Eibach Pro Kit?
Just installed the springs: no alignment
12.82%
Installed the springs & performed alignment at the same time
17.95%
Installed the springs; performed alignment later
41.03%
Installed springs & camber kit (please post which kit below)
28.21%
Voters: 39. You may not vote on this poll
Eibach Pro-Kit: Camber kit or not?
Old Jan 24, 2009 | 06:05 AM
G37Sam's Avatar
G37Sam
yeah I don't wanna go through the headache of doing it manually at shops, service is in around 4000 kms ill have them checked then
Old Jan 24, 2009 | 11:30 AM
soolman32's Avatar
soolman32
Will you get negative camber if you go the coilover route?
Old Jan 24, 2009 | 01:44 PM
vinnys coupe's Avatar
vinnys coupe
coilovers are adjustable, depends how low you would want to go^, if you dont want to go more then like 1.2-.08 then no your not going to need camber anything lower i will say most likely.
Old Jan 24, 2009 | 01:45 PM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
If you wanna remain with in factory spec with coilovers, your drop is gonna b extremely small, similar to Tanabe springs.
Old Jan 24, 2009 | 09:42 PM
soolman32's Avatar
soolman32
Thx StillBallin37 and Vinnys coupe for the reply.
Old Jan 25, 2009 | 11:31 AM
intricate's Avatar
intricate
I just had my alignment done after 2 weeks on the prokit. The dealer was able to align it back within oem specs.
Old Jan 25, 2009 | 12:20 PM
w0ady's Avatar
w0ady
installed my springs and getting my alignment thursday (2 weeks after install). as long as i can get the toe close to 0, i dont mind running -1 or -2 camber. ill decide then if i need camber kits.
Old Jan 26, 2009 | 01:12 AM
BiskitG37's Avatar
BiskitG37
I'm getting my Eibachs put on later this week. Have a couple of questions after reading all of this thread.
Is there any advantage to getting an alignment right away, then again in 2 weeks, or just get the alignment in 2 weeks?
Also, should I have my camber kit put on same time with the Eibachs, or wait til the 2 week alignment?
Old Jan 26, 2009 | 04:27 PM
sTiLLBaLLiN37
just wait 2 weeks for the alignment. The springs are gonna take a while to settle in, so getting an alignment right after will defeat the purpose of that.
Old Jan 26, 2009 | 09:00 PM
w0ady's Avatar
w0ady
correct, just wait 2 weeks. you can do some figure 8s in a parking lot after the install to help the springs settle but its still a good idea to give them time with the weight of the car.
as for the camber kits, im waiting til after the alignment. as long as i get my toe close to 0, i dont mind running some negative camber. toe is really what will kill your tires.
User 122320
Oct 5, 2015 03:03 PM
VQCrew
Sep 26, 2015 01:19 PM
jfisher
Sep 9, 2015 04:17 PM
jfisher
Sep 8, 2015 04:16 PM
