The OEM+/Comfort S Sedan Coilover Thread
Old Oct 29, 2024 | 08:53 PM
socketz67's Avatar
socketz67
Community Builder
Originally Posted by PDG
Another factor here: the base/Journey OEM springs are expensive. 4 new OEM springs run $1300.
Front: https://www.z1motorsports.com/front-...d-p-13638.html
Rear: https://www.z1motorsports.com/rear-s...d-p-13660.html
Add in shocks/struts, and you are looking at $1800. https://www.z1motorsports.com/shock-...t-p-17210.html
Depending on what someone chooses, decent coilovers are cheaper
If you are starting from scratch, I guess coilovers make alot of sense, but I love my Swift Springs and have tuned everything else around them.
Any thoughts on the TEIN EnduroPro Plus dampers? Looks like I may be a pioneer running these...
I also called KYB and their product support was essentially someone reading from the website. TEIN's support was impressive.
Old Oct 30, 2024 | 02:29 PM
bdlpe1's Avatar
bdlpe1
Interesting. I understood, with Swift Springs, that 8" front and rear would be needed to start out at stock height. So 7" front and 9" rear don't seem to jive, unless it's does a difference in how Swifts settle vs FA springs. And the rear stiffness seems low at 5K-6K....Why did they recommend this low number? Thanks.
Old Oct 30, 2024 | 04:23 PM
PDG's Avatar
PDG
Can you provide more context? Are you saying you have FA already and it isn't what you wanted? Or are you commenting on something posted above? Divorced or true coilover?
Old Oct 30, 2024 | 04:43 PM
bdlpe1's Avatar
bdlpe1
Just commenting on your posts. I've just been recently looking into coilovers for my sedan (divorced) and trying to educate myself. Appreciate your comments.
Old Oct 30, 2024 | 07:09 PM
PDG's Avatar
PDG
@bdlpe1 Ah, thanks for clarifying. The 7" front and 9" spring rear with a rear spring rate of 5k-6k refers to converting to a true-coilover from the OEM divorced setup. Changing the location of the spring changes how much leverage the spring is under, thus a different spring rate is required. The true-coilover setup FA recommended to me was with their springs.
As far as the length of spring required, I am not an expert here, but just going off of what I've learned from searching the forum. There are multiple posts about needing 8" springs (divorced) in the rear of a G37 to avoid the rear being too low. I haven't seen any posts that talk about the front being too low. They may be out there, but if they are, I haven't seen them. Here is a good example: https://www.myg37.com/forums/brakes-...l-too-low.html
The other thing I'll add is that from all my research, it seems critical to communicate directly with your coilover company to discuss your goals and then order specifically what you need. If you just order the default setup you may well be unhappy.
Old Oct 30, 2024 | 07:43 PM
PDG's Avatar
PDG
Another update, inspired by @socketz67 I picked up the phone and called Swift. I see they list a ton of metric springs on their website, so I asked if they had a spring that would allow me to maintain an OEM-ish ride height, and the answer was no. They suggested going the coilover route.
Old Oct 30, 2024 | 08:09 PM
My front end is dropped on Swifts, and I'd like it better a 1/2" higher.
Old Nov 4, 2024 | 07:29 PM
PDG's Avatar
PDG
I think I have found my coilovers - Powertrix Sport Street coilovers. I have spoken with the owner, Charles, via email and phone, and I think these are exactly what I am after. These coilovers will allow an OEM-ish ride height on sedans, and should be "very compliant for daily driving with the family" and "feedback from customers is 'rides just as good, if not better than stock.'" They also have more hardcore options for those wanting to track their cars. Powertix is a relatively small company, primarily making coilovers for Nissan and Infiniti cars.
The spring rate is 12k/10k (divorced), which initially concerned me. However, Charles explained that the spring rate and damper specs need to be properly matched to achieve the desired ride quality. Lower spring rates in a coilover can actually cause a worse ride, as the suspension can bottom out too soon. They have specifically matched their dampers and spring rates for our chassis and use. This makes sense, and I've ran into this in the dirt bike world. A harsh fork can be a spring that is too stiff OR too soft. When the springs are too soft, you end up sitting in the stiffer part of the damping, resulting in harshness. They also offer Swift springs, which Charles said ride noticeable better than the stock Powertrix springs. Just about everything I read about Swift springs say they are worth it.
These coilovers are $1700 with the Swift upgrade. They are made in Korea to Powertrix specifications. Rebuildable, zinc-coated, and come with upper mounts.
I like supporting companies that are specifically supporting the Nissan world. Plus, it's cool to interact directly with the owner who knows the cars and product so well.
https://www.powertrix.com/component/...34ss1?Itemid=0
Old Nov 4, 2024 | 09:45 PM
socketz67's Avatar
socketz67
Community Builder
@bdlpe1 Can you provide context for your post by using the quote function as its difficult to read all of the posts in an individual thread thread that's active.
I run Swifts on a RWD and they settle .3-.4 inches lower than their advertised drop. Not really an issue if you run adjustable UCAs in the front and adjustable camber arms with toe bolts in the rear. Almost any drop will require these components to maintain factory alignment specs.
Old Nov 4, 2024 | 09:49 PM
socketz67's Avatar
socketz67
Community Builder
If I'm not mistaken, Powertrix has been providing suspension solutions for the Silvia (S13) and 300ZX for some years now. Good to see them fold the G under their umbrella as well.
Old Nov 4, 2024 | 10:01 PM
socketz67's Avatar
socketz67
Community Builder
Per their marketing...
Lowering
Front: -1.2 Inch, plus .3" settling or 1.5" total.
Rear: -0.8 Inch, plus .3" settling or 1.1" total.
You prefer just a 1"drop in the front. I could have sworn TEIN made springs for our cars early on that were more conservative than the S and H Techs available today.
370Z springs are shorter, so maybe they'd give you the ride height you want?
Swifts are the ideal drop on AWDs, but they do settle a little low on the RWD sport sedan.
Old Nov 5, 2024 | 08:55 AM
bdlpe1's Avatar
bdlpe1
And the Swift springs/shock body are the right lengths to be able to start out at stock height? Great info here, thanks!
Old Nov 5, 2024 | 10:17 AM
RobC7's Avatar
RobC7
Take a look into Annex coilovers, they are a small company that makes custom quality coilovers that don't sacrifice ride quality.
https://annexsuspension.com/infiniti...sedan-g35-rwd/
Here's some great information around the company:
Old Nov 5, 2024 | 10:08 PM
  #29
socketz67's Avatar
socketz67
Community Builder
You often learn a lot when you call these vendors. The guy at Mevotech taught me how the angles work with alignments included tradeoffs on tire wear and certain types of handling characteristics. He also explained the SPC rebox technique Moog and Mevotech use. The TEIN US guy just turned me onto a great vendor that then offered me a wholesale price on a set of EduroPro Plus dampers. The KYB sales rep read from the selector guide on the website, which was disappointing . Looks like I may be the first to use the EnduroPro Plus units.
Old Nov 29, 2024 | 01:44 PM
  #30
PDG's Avatar
PDG
FYI - PowerTrix SS coilovers are on sale. There is also a pre-order option for delivery in March/April, which is perfect for me. I am not looking to install until the spring since winter is starting here. I placed my order this morning.
https://powertrix.com/component/jsho...-sale?Itemid=0
