Do I need a Rack & Pinion replacement?
Old Sep 21, 2023 | 11:19 AM
kcdc's Avatar
kcdc
I took in my 2011 Infiniti G25X for an oil change at my local Meineke and was told that I have power steering and oil leaks and need a rack and pinion replacement (I was quoted $2800).
I have included a link with some pictures they provided, and they said there’s no way to fix the leak other than replacing the rack and pinion. Is there no other way to fix the leaks (other than spending $3K)?
See pics here: https://imgur.com/a/6Ko9nUU
Infiniti 2011
G25X
86K miles
Old Sep 21, 2023 | 11:38 AM
mummy2's Avatar
mummy2
Try using ATF with stop leak or a separate bottle of atf stop leak. Couldn't hurt. Had a leak in my Volvo for years that I used stop leak on. Would just top up every couple of weeks. If it gets low you'll hear it whine and that's your signal to top up.
Old Sep 21, 2023 | 11:39 AM
Highly doubtful. Unless your steering is making a noise, or you're needing to refill your PS fluid reservoir every few months, what you're seeing is typical fluid weeping behavior on the G's steering rack. Wipe it down and look at it again in 6 months.
If you're really concerned, pay for a diagnosis at your Nissan/Infiniti dealership... not a Meineke franchise.
These kinds of threads occur a few times every year.
Old Sep 22, 2023 | 09:48 PM
socketz67's Avatar
socketz67
Community Builder
@BULL has a related post on this topic here: https://www.myg37.com/forums/brakes-...moist-fix.html
bhmclaughlin15
Jul 27, 2022 10:58 AM
G37fan09
Jan 19, 2022 11:41 PM
dirtnapper56
Mar 14, 2020 12:18 AM
drizzy315
Jan 26, 2020 07:53 AM
rijc99
Nov 12, 2011 01:11 PM
