AWD , ABS , and Traction control lights on
Old Jul 7, 2019 | 06:16 PM
thatvqnick's Avatar
thatvqnick
Hi so i have a g37x tuned by uprev and i went to jump my buddys jeep .. after attempting it those 3 lights came on and wont go away.. ill try disconnecting my battery and letting it al reset but if anyone had a similar problem or know whats up id appreciate the help!!
Old Jul 8, 2019 | 12:54 AM
slartibartfast's Avatar
slartibartfast
Check your brake fluid level.
Old Jul 8, 2019 | 02:52 PM
thatvqnick's Avatar
thatvqnick
Brake fluid is topped off
Old Jul 9, 2019 | 12:46 AM
slartibartfast
Then check for a blow fuse.
Old Jul 9, 2019 | 01:10 PM
thatvqnick's Avatar
thatvqnick
I figured it out its my front left speed sensor
Old May 23, 2021 | 12:01 PM
Niko Lang's Avatar
Niko Lang
Hi, I put lowering springs on my g37x coupe and the same three codes popped up. When taking out the strut I did hit a wire which I believe to have been the wheel speed sensor. The wire looked fine and nothing happened but days later the 3 codes came up. I later went on and took off the wheels and found that the brake line nut was lose and I tighten that and also tightened the bolts on the struts up top and the codes went away. However, a few days later they came back and I checked everything was good. I believe it’s my wheel speed sensor but I don’t know how to fix that. Do I need a new one or is there anything I can do to fix it and get rid of the codes. If you have any suggestions please let me know!!!!
Lt8Che
91
Apr 8, 2022 04:55 PM
Banshee
Apr 23, 2019 06:39 PM
ARogers502
Mar 22, 2019 02:39 AM
Dj1ofDet
Mar 19, 2014 10:47 PM
Gvilleguy31
General Tech Questions
Mar 3, 2014 03:56 PM
