Brakes n rotors
They have a third pad now (technically three if you count their racing pads) they call Street Select so make sure you get the right one. "Street Select Front Brake Pads by StopTech®. StopTech is proud to announce the release of its Street Select friction program. Using a single part number family, the Street Select friction program contains both Semi-Metallic and Ceramic application-specific formulations. Street Select brake pads are positioned just below StopTech’s Street and Sport pads in friction coefficient and wear."
Whereas the Street pads: StopTech Street Performance brake Pads are engineered to meet the demands of high performance driving while maintaining the refinement and comfort expected in everyday driving conditions. StopTech brake pads combine the benefits of premium street brake pads with aggressive friction formulas suitable for track day and autocross use. Para-aramid composites are specially formulated to provide linear response at both cold and hot temperatures, delivering optimum stopping performance over a wide range of driving conditions."
I had to replace my rears and found a deal on Street pads on Amazon. They had a "Used - Like New" in the original box and still wrapped (someone must have bought the wrong ones and returned them) for ~$18
That's what I've done, use VHT Flameproof paint, and if you want the slots to show up better you can mask off the area on the rotor that scrubs the pads but leave the slots unmasked then paint over the whole rotor. And leave about a 1/4" into the scrub area unmasked so you'll get a clean cut line when you first bed in the pads.
Hey guys I'm thinking of changing my setup for the brakes I posted about earlier, I'm thinking of (centric premium rotors part#120.42080) with some (Akebono pads part#ASP888) all from rockauto n shouldn't be no more than 250 for everything.
UPDATE!!! Total was $324 after shipping still a good deal.
Hope you didn't order yet~
You'll need (2) 12042088 Rear rotors, (2) 12042080 Front Rotors, You'll need ASP905 pads for the rears, you have the correct ASP888 pads for the front.
And a 5% discount code, enter in the "how did you hear about us" section in the cart
10703653554843330
10703653554843330
10703653554843330
10703653554843330
"Thanks
Hey blnewt, which setup is better in your experience. Personally I'm leaning towards the centric with Akebono, also the pads that come with the stoptech kit are the street select which are the pads with the least performance out of the 3 version that stoptech make.
I'd go w/ the Centric/Akebono combo or get the Stoptech Street pads (the mid priced pad, not the Street Select) on Amazon (about $100 for front/rear set) 308.08880 front 308.09051 rear and the rotors should be about the same price there vs. rockauto since shipping is free on Amazon.
Thought you were going w/ Centric Premiums??
Here's the Stoptech rotor listings though
https://www.apcautotech.com/automoti...ems?b=StopTech
Gnomercy1337
13
Jan 16, 2019 09:59 AM
n the 1/4 sliver trim, did u start to remove the tape?
