Help FML! Hit a rock on fwy! Sub frame damaged
Old Oct 11, 2018 | 07:30 PM
laser11801's Avatar
laser11801
Exclamation FML! Hit a rock on fwy! Sub frame damaged
So one day on the freeway, hit a pretty good size rock!! yes rock in the middle of the freeway.
Visually I can see so far:
1) engine subframe undertray damaged
2) O2 sensor plug was damaged
3) undercarriage plastic panel ripped.
Now the question is.. with the sub frame damage, shall I replace it? Ive heard 1) don't worry about it, its not going to any further damage 2) drill a hole at the end of the crack to stop further cracking 3) change it.
What do you all think?
Thanks,
Eddie =)
Old Oct 12, 2018 | 08:21 AM
Baadnewsburr's Avatar
Baadnewsburr
I'd be concerned about it being bent/twisted in ways that are not readily apparent which may affect other components.
maybe welding it may be an option too?
you can probably get replacement pretty check form ebay/ a wrecking yard, the greater cost will probably be in the labour, I dont really know what involved with getting the RWD front subframe off.
either way post an update when you decide on how
Old Oct 13, 2018 | 02:07 AM
crookncastle's Avatar
crookncastle
isn't this what auto insurance is for? since you ran over the giant rock, under insurance rules and guidelines it is considered a collision. just pay the deductible and have the body shop replace the subframe, o2 sensor, and undercarriage panel. btw i have never heard of anyone welding cast aluminum so don't go that route unless you are willing to face some more boo boos.
Old Oct 13, 2018 | 02:07 PM
slartibartfast's Avatar
slartibartfast
Cast Al can be welded but it's a finicky process that requires experience and a MIG welder.
Old Oct 13, 2018 | 05:02 PM
stealthee's Avatar
stealthee
Cast Al can be welded but it's a finicky process that requires experience and a TIG welder.
Fixed that.
Welding cast aluminum is very doable and I know many people that can and have done it.
Old Oct 14, 2018 | 01:23 AM
laser11801's Avatar
laser11801
yea, I am looking into fixing it. I saw that people selling that metal piece called "front suspension subframe stay assy" like this ( https://www.ebay.com/i/152643812435?chn=psfor ) about $60/70 which isn't the problem. I guess what I am wondering is what's behind that piece? Is there anything attached to it or is it just a metal piece the body shop could just bold on/off OR do they need to take off the entire chunk of parts behind it?
Any clue?
Old Oct 14, 2018 | 03:17 AM
hobbs's Avatar
hobbs
Did you hit a rock that was stationary or a rock that was moving across the road? Stationary = collision, moving = comprehensive. Info from my insurance agent. Saved me a bundle when the exhaust pipe got crushed.
Old Oct 14, 2018 | 03:26 AM
laser11801's Avatar
laser11801
It was a rock in the middle of the freeway in the middle of a lane, def a moving rock cuz it was gone the next hr. Probably some debris that was left behind from the freeway re-pavement the night prior.
enuff4life
General Tech Questions
Aug 17, 2017 08:38 PM
tomskullz023
May 26, 2012 01:05 PM
1BadAssG
Nov 7, 2010 10:16 AM
Goonz
Mar 5, 2010 03:12 AM
Kev G37S
Southern California
17
Apr 9, 2009 01:10 AM
