Camber kit?
Old May 12, 2018 | 10:20 AM
Jbunz's Avatar
Jbunz
Camber kit?
Hey guys I need help. Lol I’m just wondering if I need camber kit because my front n rear is at -2.2 all of the are the same. I’ll post the alignment sheet. Thanks
Old May 12, 2018 | 02:18 PM
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
That's close to what I run. -1.8 rear, -2 front. Tire wear isnt too bad. You could get away with some rear toe/camber bolts. Front isnt too terrible, but if you really want perfect alignment without any stance to it, it will cost ya for the front.
Old May 12, 2018 | 02:59 PM
Bommerang's Avatar
Bommerang
Ive been at -2.2 in the back for over a year, and the tire wear I can't even notice. Just keep up with rotations and make sure the toe is dialed in, and everything will be good. The same should go for the fronts, although I got the SPC arms either way but as stated above its expensive lol...
Old May 12, 2018 | 03:43 PM
Jbunz's Avatar
Jbunz
Thanks guys I guess I’ll juss let it be . Yea was thinking the same maybe jus the toe/camber bolts? Are they the same bolts?
Old May 12, 2018 | 04:22 PM
Ricio1991's Avatar
Ricio1991
As long as toe is in the green I wouldn't worry -2.2 camber isn't bad I run -1.8 -1.9 never had issues and tires last with equal tread wear
Old May 12, 2018 | 06:55 PM
slartibartfast's Avatar
slartibartfast
I've run -2 degrees front and rear for several years. I have no issues with camber wear because of very small toe settings.
Old May 13, 2018 | 09:38 AM
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Different bolts. Camber bolts are a bit shorter if I remember right. Usually, if you get a rear camber arm kit, it comes with toe bolts. Rear is not too expensive, so well worth the upgrade.
mdanish4
Feb 12, 2016 07:31 PM
hizzle101
Aug 28, 2014 11:17 PM
gonzo007
Feb 3, 2012 07:53 PM
stickboy
Mar 14, 2011 07:31 AM
AndrewDDS
24
Jan 26, 2009 09:00 PM
