Negative Camber Questions
Old May 13, 2018 | 02:09 AM
Tucsontripleb's Avatar
Tucsontripleb
1. How much negative camber did you get after installing Eibach springs? I got -4.5 with stock cam bolts set to maximum positive setting.
2. What is the maximum negative camber that does not impact tire wear (-1.0?). I drive 90% highway and a lot of miles/year, so I need to maximize tire wear.
Thanks.
Old May 13, 2018 | 06:46 PM
Surfnazi's Avatar
Surfnazi
Camber doesn't kill tires it's the toe
Old May 13, 2018 | 07:22 PM
slartibartfast's Avatar
slartibartfast
Camber wear is real but nothing like toe wear. I run -2 degrees front and rear and get decent wear. Still a little too much toe-in...
19"
248
Jun 10, 2025 08:21 AM
b2autodesigns
Brakes/Suspension
467
Jun 8, 2018 04:53 PM
b2autodesigns
Brakes/Suspension
573
Mar 29, 2018 11:18 AM
