Need help with my new brakes.
Old May 8, 2018 | 09:59 AM
Mhashif's Avatar
Mhashif
Question Need help with my new brakes.
So recently I changed my brakes with Akebono ceramic brake pads and Centric Rotors. The brakes feel slow with the response and I don't feel like they are quick to stop the car. What are some suggestions to fix this problem? TIA
Old May 8, 2018 | 10:36 AM
Entcee's Avatar
Entcee
Did you bed the pads according to the manufacturer?
Did you replace the hardware (springs and pins)?
Are you sure the springs are actually on the edge of the pads (and did not fall to the inside of the pad)?
Did you grease all the appropriate places?
Old May 8, 2018 | 10:40 AM
Mhashif's Avatar
Mhashif
Ok so I was reading about it and I actually didn’t bed in the pads properly but all the hardware kit and spring are in place properly. I think that me not bedding in the pads had to do with it not performing well. I’ll try bedding in the pads and let you know what happens.
Old May 8, 2018 | 10:43 AM
Baadnewsburr's Avatar
Baadnewsburr
what were your old pads? the new ones may be less aggressive.
Also try bleeding the brakes if you haven't.
Old May 8, 2018 | 10:48 AM
Mhashif's Avatar
Mhashif
I had stock oem brakes before and they weren’t ceramic before. And I’ll try bleeding the brake and putting in new brake fluid. Thank You
Old May 8, 2018 | 08:58 PM
Ceramic pads typically are more of a moderate street pad that won't dust, last a long time, cost less, and stay quiet. For many this is a good choice, if you want a better performing pad you'll get more dusting, shorter pad life, can get noisy, and cost more.
FWIW Ceramic pads don't typically require bedding, it's not a bad idea but check w/ the specific pad model/manufacturer regarding that.
So the choice is yours
corvin
May 21, 2018 01:07 AM
thelimit
May 10, 2018 11:02 AM
laurante
May 3, 2018 11:36 AM
tastyrice
Feb 14, 2018 01:37 PM
