RSB question
Weird question. I purchased a G37 RWD rear sway bar for my 2013 G37x. It came with the bushings but not the brackets. I realize it is a larger bar, but would I be able to use my stock brackets or would I have to buy brackets specific to that sway bar? I'm thinking I may be able to use the same brackets only because they both bolt up in the same location. Thanks in advance.
You're absolutely right. Im just the type of guy that likes to know everything is gonna work out (for the most part) before I start to take stuff apart. I just figured someone on here may know the answer.
brackets should be the same...bushings are just hollowed out more to accommodate the thicker bar
slotterjordan
Oct 9, 2016 04:08 AM
BluAnimal
Buying & Leasing
Sep 27, 2016 05:57 PM
