Overview before I order coilovers
Hello all, after reading and looking I want to post here what I am thinking and see if it lines up with reality.
I have a 2008 G37s coupe with stock wheels. I want to put 245/40 on the front and 275/35 on the back on the stock rims. I want to buy coilovers and lower the front 2 inches and the back 1 inch.
Here are my questions:
I want to make sure I think of everything before I put coilovers on and run into some pain in the "a" problem.
Thank you very much for advice, thoughts, and input!!
- Will I be able to keep the camber in factory spec without rolling or trimming the finders, so the wheels won't rub?
- Do I need front and rear camber kits to adjust the camber enough to keep it in spec?
- Will an alignment shop know how to adjust the aftermarket camber kit?
So I am going to need to spend, realistically, $2000-2500 to do it right... shucks.
I remember the old days with my 98 civic when I could simply cut a coil off each spring without even removing the strut from the car, and it was free!
You COULD do that with a 98 civic, but it didn't change the spring rate. I also remember guys taking a torch to those springs to lower the car...also a bad idea.
Troll the Porsche and Miata boards and find out where those guys are taking there cars for alignments. Lots of modded cars in those communities that are serious about their alignments.
DevilsG37s
22
Feb 11, 2022 07:30 PM
xnick101
Dec 26, 2016 11:59 PM
Detailed Image
Lighting/Cleaning Products
Dec 3, 2015 08:59 AM
Emillion45
Oct 31, 2014 03:54 PM
