Help Aligning the rear LCA bolt?
Old Dec 11, 2017 | 03:10 PM
future62's Avatar
future62
I am trying to settle on a rear ride height for my G on Tein Basis Zs and I need to remove the rear bolt and remove the spring to make the adjustment. I did it this weekend; problem is getting the bolt lined up is a PITA. I stripped the bolt on one side and ruined the nut on the other. Does anyone have any kind of tricks to get it aligned properly and easily?
Old Dec 11, 2017 | 05:31 PM
PNW_IPL's Avatar
PNW_IPL
hammer
pry bar
extra jack
patience
long screw driver
trial and error have to get aligned use jack to get it close then pry bar to help and if need be screw driver in the hole to perfect it. Then and only then put bolt in to ensure it doesnt strip!
Old Dec 11, 2017 | 05:51 PM
Bommerang's Avatar
Bommerang
I used an extra jack as well to get my bolt lined up when I did my rears, and the fed it through slowly with a ratchet after making sure both sides were lined up.
Old Dec 11, 2017 | 06:45 PM
Found it pretty easy to lift the back on jackstands and use a floor jack to load the spring bucket, made it easy for me the few times I've done that.
Old Dec 11, 2017 | 09:39 PM
future62's Avatar
future62
Loading the spring bucket is not too bad; that's what I do. It's getting the bushing on the knuckle to line up with the holes on the control arm.
Old Dec 11, 2017 | 10:22 PM
PNW_IPL's Avatar
PNW_IPL
pretty sure thats what we'v been discussing....
Mg37
Aug 4, 2016 04:33 PM
Ricio1991
May 21, 2016 05:56 PM
BLKICE
Oct 11, 2009 08:31 PM
