Rear coilovers damping adjustment
Old Oct 27, 2017 | 06:37 PM
xxg00w0's Avatar
xxg00w0
Originally Posted by PNW_IPL
Mine do rear especially
so is the clunky noise normal during low speed on our cars with flex z? im about to head to my installer to have them check it out..
Old Oct 27, 2017 | 06:41 PM
PNW_IPL's Avatar
PNW_IPL
Id say its commonly normal with zs and gs the way our suspension is designed
Old Oct 27, 2017 | 07:03 PM
xxg00w0's Avatar
xxg00w0
Originally Posted by evil-G-nius
I just got the Flex Z's also but I did not get the EDFC controller. Not sure if that was a mistake yet or not. LoL. OP, are your coils a little noisy in the rear at low speeds? Clunky?
yes i have I was think it was the ****ty installer...
Old Oct 27, 2017 | 07:04 PM
xxg00w0's Avatar
xxg00w0
ok that will save me a trip to that place... any other have the same noise problems?
Old Oct 27, 2017 | 10:15 PM
saywat?'s Avatar
saywat?
wat clunk?. i have tein basis z i have no noise no clunk. did u slam it?
Old Oct 27, 2017 | 10:25 PM
user 70824363464's Avatar
user 70824363464
Did you guys torque the top lock nut down in the rear? I found that mine made a lot of noise too until I tightened it down.
Old Oct 30, 2017 | 12:52 PM
xxg00w0's Avatar
xxg00w0
Originally Posted by chrisko
You should be able to access it by just taking the wheels off. Assuming that you can reach up there, you don't need to remove the struts.
ok I see what you were talking about. I was able to stick my finger in there and turned the ****.
Thx
Old Oct 30, 2017 | 01:17 PM
MaQG37's Avatar
MaQG37
It's a common issue on the BC coilover. After I setup my Flex Z's pre-load correctly, 0 clunking in the rear. There is an issue with your pre-load, spring isolator, or the top of the strut needs to be re-torqued.
Old Oct 30, 2017 | 02:29 PM
evil-G-nius's Avatar
evil-G-nius
once I put like 500 miles on it my mechanic said bring it back and he would re-adjust some things...I'll have him look at the top of the strut and see. Cuz it is noisy at low speeds...sounds loose though it doesnt feel like it
Old Nov 4, 2017 | 08:29 PM
supreme's Avatar
supreme
I have no clunk. Top nut was loose from factory. Made sure to torque down before installing as another person had the same issue. After doing that, I had 0 issues.
And I am glad I peeped in here. Setting at the recommended 12 position works very well in the back. However, I always wondered wtf the rubber grommets were. I was planning on dropping the strut if I ever had to adjust. Glad I do NOT anymore.
Old Nov 10, 2017 | 04:50 PM
evil-G-nius
apparently with the flex Z you can't preload the rears because of the seat position. They sit in the cup like the stock springs. IDK...we'll see
