Rear coilovers damping adjustment
anybody adjust their rear shock damping before? I have Tein Flex z so have to adjust it from the top of the shock. our car doesn't have opening on the rear to adjust it right or did it?
My Megan Street LP coilovers have the adjuster **** side mounted on the upper shock section, so it's a simple adjustment, just jack the rear up to get enough room to get your hand up there and turn the adjuster. AFAIK quite a few of the Taiwan sourced COs are that way.
EDFC is nice. but are there any ways that I can adjust it without taking off the rear shocks? I have it set at +2 and I feel it's a little soft my rear wheels are rubbing the liner...
The Pro has 4 wheel independent automatic adjustments for longitudinal and lateral G forces and speed. The EDFC II has 3 static presets for front and rear. So the front pair ot rear pair of shocks are not independent.
so my only solution is to remove the struts and turn the damn *****.....
the G35 guys they did something like this, https://g35driver.com/forums/brakes-...35-coupes.html
is it possible to do something like this to our cars?
You should be able to access it by just taking the wheels off. Assuming that you can reach up there, you don't need to remove the struts.
I just got the Flex Z's also but I did not get the EDFC controller. Not sure if that was a mistake yet or not. LoL. OP, are your coils a little noisy in the rear at low speeds? Clunky?
