Want to lower my Vert
Old Mar 17, 2017 | 07:53 AM
kiseliok's Avatar
kiseliok
G37 Community Team
Originally Posted by HottRodd
@kiseliok I'm kinda old too lol, no reason to be ordinary
Haha. Keep on keeping on then! It's nice to see others with modified verts.
Old Mar 28, 2017 | 11:10 AM
HottRodd's Avatar
HottRodd
springs installed
Old Mar 28, 2017 | 11:17 AM
dalastcwood's Avatar
dalastcwood
springs installed
Looks great, man! Any issues while driving (rubbing, bottoming out, etc.)? Also, did you install anything else besides just the springs themselves?
Old Mar 28, 2017 | 12:24 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Looks great. Same questions as above - how's the ride?
Old Mar 28, 2017 | 02:05 PM
HottRodd's Avatar
HottRodd
Eibach prokit and SPC camber/toe bolt kit in the rear. Fender liner trimmed in the rear. It rides great and I love the look. No rubbing yet and hasn't bottomed out. Running 20x10.5 +25offset (no spacers) and 285/30 tire in the rear. Alignment camber is out of specs a little, .3 degrees in the rear. Question...does the bottoming out come with time??
Old Mar 28, 2017 | 02:14 PM
Looks really nice there^^^, what part # is that Eibach kit, do they make a vert specific spring? Or were these regular coupe springs? Nice job on the alignment and looks like good wheel/tire fit too, what wheel/tire spec are you running in front?
Old Mar 28, 2017 | 02:26 PM
HottRodd's Avatar
HottRodd
@blnewt part#Manufacturer Part #: 6388.140. I have STR Racings Vossen Replica's.. yeah I know but they came in more aggressive offsets and were much cheaper. Front 20x9 +18 245/30, Rear 20x10.5 +25 285/30. I was running these on my G35 coupe and just switched them out when I bought the vert.
Old Mar 28, 2017 | 02:29 PM
HottRodd's Avatar
HottRodd
H&R had some G37 Vert spring on the tire rack store but they said not compatible with hardtop vert just the roadster...I was confused so didn't go that rought.
Old Mar 28, 2017 | 03:07 PM
kiseliok's Avatar
kiseliok
G37 Community Team
So if this is correct, 350 lb/in = 6.2 kg/mm and 550 lb/in = 9.8 kg/mm, your variable spring rate is actually stiffer than stock coilover linear springs. Rear springs on BC are 8kg and on D2 is 8.7kg. Very interesting.
Old Mar 28, 2017 | 03:12 PM
Don't feel bad about those STRs, looks like they had what you wanted in the proper offsets, and saved you some cash, should get your moneys' worth, hard to argue w/ that.
So is that Eibach spring# a vert. specific part?
Old Mar 28, 2017 | 03:39 PM
HottRodd's Avatar
HottRodd
These were not vert specific. They were for the coupe
Old Mar 28, 2017 | 03:41 PM
HottRodd's Avatar
HottRodd
https://www.tirerack.com/suspension/...efore+3%2F2010
Link to the site I got them from. Tire Rack had the best price when I bought them.
Old Mar 28, 2017 | 03:56 PM
HottRodd's Avatar
HottRodd
Not sure about the spring rates
Old Mar 29, 2017 | 10:19 AM
  #29
HottRodd's Avatar
HottRodd
Old Mar 29, 2017 | 11:15 AM
  #30
kiseliok's Avatar
kiseliok
G37 Community Team
Looks great. Now you just need a proper set of brakes.
