Many dash lights on
Old Dec 6, 2016 | 11:00 PM
tbssimp's Avatar
tbssimp
Many dash lights on
So I just got my first G37 a few weeks ago. I own a G35 and FX35. I have a bunch of dash lights on. The brake only comes on every once in awhile when I get on it. I checked the tire pressure, brake fluid and the remote key works fine but all these lights are on. Any idea why all this lights would be on?
2012 G37 coupe S
I am new to the 37s and its been awhile since I have worked on cars in general so I would def say I am a newb. I also posted this in the newbe corner. Sorry for the double post. I am still learning my way around this forum.
Thank you!
Old Dec 7, 2016 | 12:20 AM
TjG37s's Avatar
TjG37s
2012 G37 coupe S
Thank you!
Looks like key battery is low, TPMS (mine is always on even though tires are fine), and traction control is off..
Old Dec 7, 2016 | 07:58 AM
UCLAG37's Avatar
UCLAG37
For the TPMS indicator, are your wheels/tires OEM that came with the 2012 coupe S? If the wheels are not original, you should also consider the possibility that one or more of the sensor batteries are dead if the wheels came off an older model or the sensors removed.
UCLAg37
Old Dec 7, 2016 | 09:02 AM
the93owner's Avatar
the93owner
What size tires do you have? Did all of the lights come on at the same time? The key light should be unrelated to the others.
Old Dec 7, 2016 | 09:24 AM
Kris9884's Avatar
Kris9884
My TPMS sensors act up when the outside temperature is drastically cold or hot, I assume it changes the air pressure enough to throw them off. Just have to go even the tires out at the gas station and it goes away for the season. Other than that, the key battery is a no brainer and the TCS is just off.
Old Dec 7, 2016 | 11:25 AM
tbssimp's Avatar
tbssimp
I will change the battery and see if it fixes that one and give an update.
Thanks!
Old Dec 7, 2016 | 11:37 AM
tbssimp's Avatar
tbssimp
UCLAg37
They are not OEM they are aftermarket. I didn't change them it was whoever owned them before.
Please see a picture below:
Old Dec 7, 2016 | 11:40 AM
tbssimp's Avatar
tbssimp
They were all no when I bought the car so I can't really answer that question. The tires are 18in. I just added some pics of the car and wheels that are aftermarket.
I am going to change the battery in the key and see if they fixes that light.
Thank you.
Old Dec 7, 2016 | 11:43 AM
tbssimp's Avatar
tbssimp
It did get cold recently but I checked the pressure and they are all right at 34PSI.
The TCS light that is on is not the on and off light that shows on a different part of the dash. I will try and send another pic of that light. The light that is on is showing TCS has kicked in but just comes on when I am driving it pretty normal. Not sure why it would kick in.
Old Dec 7, 2016 | 11:53 AM
the93owner's Avatar
the93owner
Thank you.
What are the specific tire sizes? 225/50/18 or something like that? It could be throwing off your traction control if there is too much difference. Also it is possible there is no TPMS in your wheels or one or more is not working properly (needs to be recalibrated or replaced). And did those wheels come off of a Maserati?
Old Dec 7, 2016 | 01:47 PM
tbssimp's Avatar
tbssimp
Wow! I never even put the two together. Looks like they came off a GhiBli.
#1981 2014 MASERATI GHIBLI ALFIERI STAGGERED FACTORY OEM 18 INCH WHEELS RIMS | eBay
Well damn I really like the wheels, maybe I can get some Infiniti caps to replace the Maserati ones.
Anyways the tires are 245/45/18. I have a Tires Plus I trust to work on my old 2003 G35 can I bring the car there to look at the TPMS or do you think I need to go to Infiniti for this?
Old Dec 7, 2016 | 01:57 PM
the93owner's Avatar
the93owner
I'm sure he can do that for you. Either you don't have any TPMS installed, or they are out of battery or need to be re-calibrated. I'm betting you don't have the right TPMS or none at all if they came off a Maserati.
Old Dec 7, 2016 | 03:22 PM
tbssimp's Avatar
tbssimp
Ok cool thank you. I will have them look into it. If there isn't any can they install OEM sensors in these wheels? Also can I turn off that light some how? I don't really care so much about the tire pressure I check them anyways and if I get a flat I'll know eventually. I lived without one for my whole life and the ones in my wife's FX are more annoying then do any good.
Old Dec 7, 2016 | 10:20 PM
soundkillr's Avatar
soundkillr
If no sensors are in the wheels, yes they can be installed. It's cheaper to go aftermarket. Just have them tested BEFORE being installed to make sure they will give talk back to the tps system. They will deflate the tire, unbead it, and install the sensor (at the valve stem)
I bought one brand at autozone, and it didn't work. Returned it, got another brand at Napa and it worked fine.....
Old Dec 8, 2016 | 06:44 PM
Elco's Avatar
Elco
The key light on the dash indicate a problem with your steering lock system on the car. That steering lock make's lot's of problems on other nissan car's that use the same electronic steering lock system (370Z, GTR, Juke, etc...).
Disabling the steering lock will fix the key light issue on the dash. There are lot's of threads on 370Z forums, GT-R forums and even on this forum regarding the steering lock module issue.
The TPMS light is related to an absent, out of sync TPMS sensor or a TPMS sensor with a dead battery.
