NEWBIE Q: suspension height G37 coupe RWD vs. AWD
Old Jun 12, 2016 | 11:33 PM
airken's Avatar
airken
I have a G37x coupe, so AWD, and I'm looking to buy Eibach lowering springs. When I look at the drop difference between the RWD and AWD for the coupe....the AWD drops 1.9in in the front and 1.6in in the back, which ile RWD drops 1.2in in the front and 0.8in in the back. Are the stock AWD coupe ride height normally higher than the RWD coupe? Just wondering if 1.9in drop may be too much, since I live in Toronto, and have to worry about snow. TIA
Old Jun 13, 2016 | 01:58 AM
I have the Eibach Pro Kit on my X coupe and don't think it's low enough. I love in NJ and the weather especially snow is pretty bad but I've lasted 2 winters so far without any issues at all.
Here's some close up pictures of my drop to compare what yours will look like on all 4 sides on an awd coupe.
Attached Thumbnails NEWBIE Q: suspension height G37 coupe RWD vs. AWD-20160610_122928.jpg   NEWBIE Q: suspension height G37 coupe RWD vs. AWD-20160610_122938.jpg   NEWBIE Q: suspension height G37 coupe RWD vs. AWD-20160610_122952.jpg   NEWBIE Q: suspension height G37 coupe RWD vs. AWD-20160610_123001.jpg
Old Jun 13, 2016 | 08:48 AM
G37xhibeet's Avatar
G37xhibeet
Yes, the AWD comes higher than the RWD coupes
Old Jun 13, 2016 | 10:55 PM
airken's Avatar
airken
Thanks! Good pics for reference! How many finger spaces is that? 1?
Did you have a to buy a camber kit? I'm guessing alignment is a must?
How is the day to day driving?
Old Jun 14, 2016 | 01:34 AM
Day driving is great I think it's A LOT better than the stock feel for sure. It's about an estimated finger space and as for camber kits you might want a rear camber kit only to be safe.
I personally have had these springs for about 2 years now without a camber kit but I got a new set of wheels and tires and noticed a little camber wear on my old set but they lasted a pretty good while.
Old Jun 14, 2016 | 03:31 AM
slartibartfast's Avatar
slartibartfast
I'll bet it was toe wear. Thrust (and wear) from camber is pretty small.
Old Jun 14, 2016 | 11:01 AM
airken's Avatar
airken
Would camber bolts do the trick? Or do I need the whole kit? I don't need a camber kit for the front? The front ones are quite expensive...so would rather not have to if I don't need it
Old Jun 14, 2016 | 02:29 PM
slartibartfast
Some people can get away without camber kits with mild drops. If you do end up with excess negative camber, be sure to have front toe set to zero and a small toe-in in the rear for stability. The car will lose its sense of straight ahead but you'll save your inner shoulder. You'll get used to it after awhile and think it's normal.
Mikey D
Apr 23, 2016 12:17 AM
fyrcapn
Sep 27, 2012 10:29 PM
GreenWeenie
Canada
Apr 11, 2012 12:10 AM
Marbs
Feb 13, 2010 02:54 AM
