Lowering help!!! Never done this before..
Old Apr 26, 2016 | 04:43 PM
SlateBlue G's Avatar
SlateBlue G
If you lower your car more than a inch you will need a camber kit for F&R.
Make sure you elongate the rear with a dremel though
Old Apr 27, 2016 | 09:42 AM
Originally Posted by m3clubracer
Get bent rear lower camber arms so you can upgrade the sway bars. I wish this was more obvious to me when I did mine.
I've got about 1/4" clearance between the SPC rear camber arms and an Eibach Swaybar dropped to 26 3/4" floor-to-fender.
Old Apr 27, 2016 | 10:07 AM
m3clubracer's Avatar
m3clubracer
I may not have .25 inches based on my rear Eibachs. I bet I will hit.
Old Apr 27, 2016 | 01:45 PM
slartibartfast's Avatar
slartibartfast
Have you measured each end of the sill to the ground? Is that level or also drooped at the rear?
Old Apr 27, 2016 | 02:37 PM
m3clubracer
It is from top of wheel arch at the same place (marked) to the level ground of my garage floor. Left and right side were +/-2mm.
Old Apr 28, 2016 | 02:28 AM
takeapieandrun's Avatar
takeapieandrun
I never got an alignment or camber arms, and after 2 years my rear tires are bald. Probably from toe to be honest. I would say I put 10K un-lowered miles and 15K lowered miles on them. Fronts are perfectly fine though.
Old Apr 28, 2016 | 09:14 AM
m3clubracer
toe links - $100
alignment - $100
tires - $$$$
Old Apr 28, 2016 | 02:17 PM
SlateBlue G
your camber can be little off but the toe is the real tire killer.
When I had my Tein S-techs even with the camber kit the best I got was -2.5 camber in the rear
Snipres
General Tech Questions
46
Sep 30, 2019 09:42 PM
Hugh Anderson
Apr 24, 2017 07:10 PM
kevinmward
May 10, 2016 05:25 PM
JohnsG37x
Mar 8, 2016 11:41 PM
jameslee79
Mar 5, 2016 10:37 AM
