G37x brake questions
Old Nov 1, 2015 | 04:09 PM
RexHavoc's Avatar
RexHavoc
Originally Posted by lorentzoe45
I think I have desided to just buy the kit listed above. Slotted only rotor, hps pads, 600 fluid. Also I added a z1 silicone brake booster hose since I'm replacing the other lines and it looks cool I guess. I'll let y'all know the results. Just not sure on spending the extra 800-1000 for the calipers when for what I use the car for the oem work fine. My rear pads are at maybe 10% so figured I'd change everything. Also I get a brake light on my car a lot on the speedo that comes on during acceleration and goes away when slowing wayyyyy down. Anybody seen this before?
Originally Posted by the_wolff
Top off your brake fluid and it will go away. I had the same thing. Light came on only during hard acceleration. Fluid wasn't real low, but I topped it off (after reading a thread here that mentioned it) and haven't seen it again.
Originally Posted by VIVID
+1 ^^^^^
I had the same thing just after I took delivery of my G. I added like four tablespoons of fluid and haven't had the light come back yet.
I'm not the best person to respond about upgrading the calipers, but IMO it's a nice, but unneeded, upgrade. The OEM non-sport brakes work just fine. But if you like modding and beautiful hardware....well....I say do it.
Sean
I just put on new pads and fluid went right back up to full.
Old Nov 2, 2015 | 01:30 PM
jason05gt's Avatar
jason05gt
Originally Posted by Mr.Grant
I agree I recently bout sway bars from a s sedan, and getting ready to install them. The guys gave me the bushings that came from his car and the bolts. Should i use that hardware or the hardware off my g37x. If i need to buy new hardware to maybe just be on the safe side should i get that hardware for the S sedan or the X sedan? Or if I should upgrade while I'm doing this what bushings and or links would you recommend?
Also Lorenzo to answer your questions about the brakes I would recommend saving some money and upgrading your breaks this way especially if you don't care about aesthetics in the mean time. This route will be fine unless you plan on doing some heavy track days with real technical turns and braking spots. But you may also have nothing to worry about if you upgrade the break fluid as well and include some stainless steel brake lines.
Also you can part an brake upgrade this style much cheaper by using sites like rockauto and the sorts. But Z1 does have a rock solid setup if you dont want to search and worry about everything matching cause they are selling it as basically a compatible kit
I just installed a 370Z rear sway bar in my X. You will have the use the bushings from the larger bar, but the bracket and bolts do not need to be swapped. It took me about an hour to install the sway bar. To be honest, it's probably the best bang for the buck mod for these cars. The thicker rear sway removes the factory understeer and the steering is more responsive. Overall, the car is much more balanced and neutral. I am not sure why Infiniti didn't put a thicker bar on the X from the factory.
Old Nov 2, 2015 | 03:35 PM
Mr.Grant's Avatar
Mr.Grant
Thanks for the info buying the g37s bushings now
Old Nov 2, 2015 | 03:46 PM
Mr.Grant's Avatar
Mr.Grant
Lorenzo, I'm going to purchase this package from Rock auto it should provide the same performance as the Z1 Motorsports package and with shipping its cheaper then their package. Although it does not come with stainless steel lines, you can probably purchase them cheaper and add some high performance brake fluid and still come out on top. catalog number: K11426
User 122320
Oct 30, 2015 10:10 PM
grojas112
Oct 30, 2015 05:43 PM
empirepb48
Oct 29, 2015 05:48 PM
slotterjordan
Oct 26, 2015 07:50 PM
shawnberry45
Oct 24, 2015 12:19 PM
