Akebono upgrade on '11 G37x sedan
Old Sep 1, 2015 | 08:48 AM
Ryne's Avatar
Ryne
The Steering Wheel Guy
OP, what rotors are you considering purchasing? I have bought budget rotors in the past and had a pretty bad experience. I highly recommend Centric Premium rotors. The slight up charge is well worth what you get in return. They are high quality parts and come with a black coating on the hat. Below are my part numbers from my order in April of 2014. I haven't had any squealing with the setup, it has been great.
Old Sep 1, 2015 | 08:56 AM
Ryne's Avatar
Ryne
I just ran the part numbers for your rotors and answered my own question. I'd still recommend moving into the Centric Premiums. For the small increase in price, it's worth it.
http://www.centricparts.com/products...m-brake-rotors
Old Sep 2, 2015 | 11:57 PM
TheLocNar's Avatar
TheLocNar
Originally Posted by Ryne
You should be able to reach in there with the wheel off and just bend the remaining metal away from the rotor.
Yeah just need to find the time. Maybe this weekend.
Old Sep 4, 2015 | 03:24 PM
ck1109's Avatar
ck1109
Ok, so I ordered the sway bars and the paddle shifters, but I thought I'd double check everything before ordering the brakes and sure enough I realized my rims were 18" (most likely these ones) and not 19".
I haven't seen any threads detailing the install on these rims specifically, but if Infiniti's website is to be believed, it seems like they fit just fine?
I think i will have the mechanic remove one of the front/rear tires when I get the sway bars installed so I can compare them against the template.
Old Sep 5, 2015 | 09:12 PM
TheLocNar's Avatar
TheLocNar
I know the duckfeet ones for my xS sedan on my 2010 will fit over the Akebonos. Not sure about those though. But our tire sizes are the same.
Old Sep 14, 2015 | 09:22 PM
ck1109's Avatar
ck1109
I had the shop verify whether they'd fit by comparing against the templates and they didn't. Their recommendation was to look at 19" rims instead of going with spacers as I'd need really big spacers.
Old Oct 5, 2015 | 09:04 PM
ck1109's Avatar
ck1109
Ok, so the entire kit is now ordered. Per Ryne's comment, I upgraded to the premium rotors.
Now I wait.....
Old Oct 9, 2015 | 01:48 PM
nbast's Avatar
nbast
Quadruple check the part numbers. They sent me two left rear calipers and I didn't notice, so my car was 3/4 converted for a few days while the replacement was shipped out and installed. I just got the car back on Tuesday. Next I have to find spacers for my winter wheels...
Old Oct 9, 2015 | 03:53 PM
Glad it worked out, too bad about the mis-order, was the error on you or them??
Car looks nice BTW
Old Oct 9, 2015 | 04:02 PM
nbast's Avatar
nbast
Car looks nice BTW
It was their error, but they shipped the replacement out overnight as soon as I let them know, so I'd have no hesitation about ordering from them again.
Thanks! I plan to put the brakes to practical use at Watkins Glen in the Spring, so it's not just a cosmetic upgrade.
Old Oct 9, 2015 | 06:37 PM
Nice! Look forward to your impressions of your new BBK test.
Old Oct 13, 2015 | 09:17 PM
ck1109's Avatar
ck1109
Double checked the part #s again today and they match up. Any idea where the part # is on the rotor? Can't see a part number on the package.
Nice looking G!
Old Oct 14, 2015 | 08:27 AM
Nice looking G!
Unless they're drilled or slotted you can just measure them, front is 355mm (14") and the rear 350mm, about 13 3/4". If they are drilled/slotted they should be the same sizes but opposite drilled/slotted direction on each rotor. Part # should be stamped on the inside somewhere or on the outside edge of the disc.
Old Oct 15, 2015 | 11:07 PM
  #29
ck1109's Avatar
ck1109
Install is done.
Old Oct 15, 2015 | 11:37 PM
  #30
Well done sir!
