4 wheel alignment needed after struts change
Old Apr 26, 2015 | 02:29 AM
pcwd's Avatar
pcwd
My driver side strut is leaking. Car is a G37S coupe with about 42,000 miles.
I plan on changing both front struts.
Is a four wheel alignment recommended/required after the struts change?
Thanks.
Old Apr 26, 2015 | 08:20 AM
chairman25's Avatar
chairman25
In short, yes. Anytime you make changes like that a 4 wheel alignment is necesssary to make sure that the suspension is set to spec. If not, the car may not track true and the result could be dangerous.
While replacing the struts in the front, what is the condition of the rear struts? With 42k on the clock, you should consider the two rears at the same time. Those struts are likely on their way out, given the mileage. Doing all four, while more expensive, will ensure that all of the wheels are reacting to steering inputs and road conditions in the same manner. Look at it this way, you'll only have to pay for one 4 wheel alignment.
Good Luck
Old Apr 26, 2015 | 08:31 AM
G37Sam's Avatar
G37Sam
42k is too soon to wear the shocks out unless you do a lot of dune bashing.
If you're going to replace them anyways, go aftermarket.
Old Apr 26, 2015 | 08:41 AM
Lego_Maniac's Avatar
Lego_Maniac
Recommend, yes. Required, no.
I'm with G37Sam in that I'd look into aftermarket dampers, such as Konis. And chairman makes a good point on replacing the rears as well for balanced ride/handling.
Old Apr 26, 2015 | 10:40 AM
Thirty_Seven's Avatar
Thirty_Seven
Konis are the bomb, very pricy but well worth it.
Old Apr 26, 2015 | 12:25 PM
pcwd's Avatar
pcwd
Rear struts are fine. Dry as a bone.
I leaking front driver strut is a slow leak. I did the bounce test on all four corners of the car and it passed. I will look into replacing all four corners. The KYB struts are about $136 for one for the front. I will check out koni as well thanks.
sLADe781
32
Nov 28, 2015 03:23 AM
james6980
Oct 9, 2015 01:28 PM
JSolo
Sep 28, 2015 02:09 PM
MeatySock
Aug 14, 2015 08:25 AM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
