Best Possible Suspension Modification for AWD coupe
Old Apr 6, 2015 | 01:35 PM
IntricateDetail's Avatar
IntricateDetail
Wannabe
I realize that this is for coupe...but other than the Swift springs, pretty much the same situation.
I don't want to just replace the springs w/ Tanabe...unless there really is no concern about the OEM shocks/struts. I saw the Koni yellow and was wondering why nobody uses that with the Tanabe NF210 springs for the X? Is it possible? If so, would the ride be that much harsher? I guess I don't want to spend the amount for the Fortune coils if Swift is doing something other than what they have available right now. Of course...I still need to do a lot of reading. That being said, what about the Swift 4N907? Why Tanabe over the Swift?
Ideally, I wouldn't mind doing the fix that Brad put me onto...
https://www.myg37.com/forums/brakes-...acer-help.html
As long as I could either 1.) Not need to worry about my OEM struts, or 2.) Get the Koni's or something on there to counter it. I don't know...just throwing stuff out there that I'm sure has already been beaten into the ground haha.
Old Apr 6, 2015 | 04:00 PM
Lego_Maniac's Avatar
Lego_Maniac
Im pretty sure the Koni's won't fit the front due to the differential/drive shaft.
I'd look into scoring a used set of Koni Yellows off the 370Z forum ($4-500), as well as a used set of front X shocks, then send them to a shop like true choice to transplant the guts of the konis into your extra set of shocks.
It doesn't matter if the Konis you get are blown....they can be rebuilt when they swap the guts.
Note I dont know if this will actually work but lots of Koni applications are "inserts" and go into stock housings--WRX for example.
Old Feb 21, 2020 | 07:50 AM
DustU's Avatar
DustU
Swift Springs WILL definetly blow out your stock shocks if youre over 35-40K Miles like they did on my 12 G37xs BUT i went with some aftermarket shocks and loving the lowered ride combined with 15MM spacers for a nice stanced(not slammed) look perfect for NY potholes! Upgrading to the hotchkiss swaybars after reading an earleir post as its a daily.
Old Feb 21, 2020 | 01:17 PM
slartibartfast's Avatar
slartibartfast
A thread that's been dormant for nearly five years. But, possibly useful for current AWD members. You do a disservice, however, by not naming the dampers you installed.
Old Feb 21, 2020 | 07:00 PM
KImChee's Avatar
KImChee
Get the Sport rear away bar it can be had for as little as $50. It makes the car more neutral and it decreases body roll. The car feels more planted and doesn’t understeer as much. Koni Yellows are a favorite of mine across multiple platforms, can’t go wrong with those
Old Feb 25, 2020 | 01:59 PM
Lego_Maniac
They don't fit the front of the X models.
Old Oct 28, 2020 | 09:16 PM
rosskuhns's Avatar
rosskuhns
ditto to star
what 'aftermarket shocks' did you use? I only know of KYB's for stockers (which some say are better than stock shocks) I've seen tokico's show for X's but only one end of the car.
G37xMN
18
Feb 5, 2020 03:55 PM
13_G37x
May 4, 2018 06:34 PM
pwcracer
Feb 27, 2017 09:29 AM
mjnoles1
Dec 18, 2015 10:19 PM
nick_oh_lie
Apr 26, 2015 03:02 PM
