SPC Cam Bolt(72265) question
Old Nov 22, 2014 | 11:38 PM
604's Avatar
604
Greetings,
I am about to order the rear arms and the bolts. I am a little confused on how many bolts I will need.
According to this eBay auction 4 are needed?
http://www.ebay.com/itm/UC018-72265-SPC-Rear-Camber-Toe-Kit-x-2-Both-Sides-for-370Z-late-G35-G37-/261229394875?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AG37&hash=item3cd27c3bbb&vxp=mtr
On all DIY articles I have read there is only one bolt per side.
Am I missing something?
Thnx
Old Nov 23, 2014 | 09:50 AM
The longer bolts should be for the toe adjust and the shorter ones for the camber arms. The 4 bolt set is all you need, and you can still adjust the OEM camber arms w/ those bolts, you just won't get the wide adjustment range that you will w/ the full aftermarket SPC arms. You will have to elongate the original bolt holes w/ a dremel tool, the template should be supplied.
Originally Posted by 604
Greetings,
UC018 72265 SPC Rear Camber Toe Kit x 2 Both Sides for 370Z Late G35 G37 | eBay
Thnx
Old Nov 24, 2014 | 08:11 PM
slartibartfast's Avatar
slartibartfast
What's this about extra bolts? I have the SPC arms that'll be installed in a week and I thought that the bolts supplied in the box would be all that's needed.
Old Nov 24, 2014 | 09:01 PM
You've got the rear camber arm w/ rear toe bolt setup. The above listing is just replacing the OEM camber bolt w/ one that has a wider range along w/ the toe bolts that you have. The arm that you have is the best way to go as it offers a wider range. The camber bolt set only has a +/- 2 degree swing. Here's a table that shows the differences
Specialty Products Company | SPC Alignment | The Automotive Alignment Leaders
Old Nov 24, 2014 | 09:21 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
All you need is an actual rear SPC arm kit*** PART #72262
The kit comes w/ both arms along with toe bolts. I sell these kits for $200 shipped within the continental US.
Old Nov 24, 2014 | 11:30 PM
slartibartfast
thanks for the warm and fuzzy. I found the camber arm and stopped looking for other options.
Simran Mann
Sep 13, 2015 01:51 AM
G37X GraSdadow
Sep 2, 2015 04:09 AM
Ipp391
Aug 28, 2015 09:27 AM
G37xS-Life
Aug 27, 2015 02:00 PM
