Camber kit needed for Swift or Eibach springs?
Old Aug 19, 2014 | 11:05 PM
halfshaft's Avatar
halfshaft
I'm planning on doing a mild drop (just enough to eliminate the ugly wheel gap) and will most likely be going for swift or eibach springs. I am wondering what kind of camber numbers you guys got after lowering on springs? I searched the forum already and most of the data I found was for sedans, many of which were awd. Any numbers for coupe/rwd owners?
I am hoping I can get the numbers to within limits after an alignment without camber kit, the camber kits would drive up the total cost by quite a bit .
Is it really that bad for tire wear if you drive around with like -1.8 to -2 camber?
Old Aug 19, 2014 | 11:11 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
I have a coupe on Eibach with a front and rear spc camber/toe kit.
Here is the short story:
Some people run no kits and swear it's fine. It's almost unanimously agreed upon that a rear kit is NEEDED to save tires from premature wear (~$140). The front kit ensures that all specs can be brought back with OEM ranges (~$300). As long as you get an alignment and make sure TOE SPECS are within the specified ranged, regardless of camber slightly out, tire wear has been noted as minimal.
Old Aug 20, 2014 | 12:08 AM
Sway_NV's Avatar
Sway_NV
I'm too young to die!
Do it right the first time. Just get the kit. It will save you money and headaches down the line.
Old Aug 20, 2014 | 12:22 AM
dtran2714's Avatar
dtran2714
I'm running swifts without a kit. The fronts are within specs but the rear is a bit out but not enough for any premature wear. I haven't had any issues on wear. Just be sure to get an alignment and make sure the toe is within specs. The rear camber was slightly out for me. I did buy the kit but didn't install it. Do what you want. If you are paranoid then buy and install the kit.
Old Aug 20, 2014 | 12:55 AM
Gio37's Avatar
Gio37
Exactly !
Did not want to install the Eibachs without F/R camber kits
Old Aug 20, 2014 | 01:13 AM
algeee37s's Avatar
algeee37s
How many miles do you have on the tires?
Old Aug 20, 2014 | 01:14 AM
Brandonboggs's Avatar
Brandonboggs
Im actually in the same boat as you, their are a lot of people who will say you don't need them, but like everyone else on here says, better safe than sorry. You should definently look into the tein h-techs too(not the s techs). They look really good, have a decent mild drop, and are normally a little bit cheaper.
Old Aug 20, 2014 | 01:22 AM
algeee37s's Avatar
algeee37s
People, put the cambers on....I had the Eibach PK on my 350z and the tires didn't last 8k. This time I did it right and I don't have to worry about premature tire wear.
Old Aug 20, 2014 | 08:32 AM
chris_s's Avatar
chris_s
another in for camber kit.
my swifts ended up with rear camber worse than 2.0, but I believe now that was because my LCA and toe adjuster bolts were seized up (canada) and the alignment guys weren't able to max out the oem adjustment in the rear
Old Aug 20, 2014 | 08:46 AM
Lego_Maniac's Avatar
Lego_Maniac
I really think it depends on how close you can get to factor specifications and the impact on tire wear. I'm currently averaging 10k out of summer tires. If it is so out of spec I'm eating through tires in 5k, then its a different story than if its close to spec and I'm getting 9k out of a set of tires.
Old Aug 20, 2014 | 09:22 AM
Jack10525's Avatar
Jack10525
Even getting 10k out of a set of tires sucks. They should last 25-30k miles. That's horrible.
Old Aug 20, 2014 | 10:19 AM
Lego_Maniac
Ive never gotten much more than 10k out of dedicated summer tires
Old Aug 20, 2014 | 12:51 PM
Ryne's Avatar
Ryne
I have seen the tides change on this forum a lot lately regarding this topic. A lot less people saying they can get away without a kit and going back to install the kits.
Just buy the pieces as your budget permits and complete the install when you have acquired all of the parts.
My previous post seems to inadvertently encourage a shoddy job, when in fact, I was just reciting the common mentality on this forum. I installed both camber kits with my Eibach's on the first shot followed by an alignment, and from my research and experience, I'd strongly advise and future suspension modifiers do the same.
Old Aug 20, 2014 | 04:01 PM
^^^Well said sir!^^^
Old Aug 20, 2014 | 04:59 PM
kevshiau's Avatar
kevshiau
I didn't have camber kits when I initially had my Eibach's installed but after a while I got very noticeable camber wear on my front tires. The rears weren't too bad, but I ended up getting camber kits installed for front and back the next time my car was in the shop.
I'm removing my front camber kits next month though
