I hear a Squeaking sound after i lowered my car
Old Aug 11, 2014 | 05:10 PM
Lances Infiniti's Avatar
Lances Infiniti
I just installed my Swift Sport Lowering Springs which was a .8 and a 1.2 inch drop. When i go over a good size bump i can hear like a deep squeaking sound? Help?
Old Aug 11, 2014 | 08:35 PM
Might be your A-arm bushings, sway bar end links, coil spring loading, and numerous other possible culprits
Can you isolate it to the front or rear and a particular side?
Old Aug 11, 2014 | 09:51 PM
Lances Infiniti
Nopeeeee
Old Aug 12, 2014 | 01:45 AM
Lances Infiniti
**** it. Ill just turn up the bass with my 2 12's haha
Old Mar 23, 2015 | 07:04 PM
G37fan09's Avatar
G37fan09
I just install Swift springs (like 2 days ago) and I feel it is the spring itself that is causing the noise when in contracts on a bump. In my case i can hear it in the front only. Any other Swift springs user with the same problem?.. any recommendations?
Old Mar 30, 2015 | 03:24 PM
HoldmyMouse's Avatar
HoldmyMouse
Recheck all the nuts and bolts to make sure they are torqued down. Is the noise coming from front or rear? The last resort on isolating the problem is to reinstall stock springs and go back to the big bumps to see if noise still linger.
slowbird
Aug 3, 2023 07:54 PM
Intake
Dec 25, 2015 09:38 PM
MeatySock
Aug 14, 2015 08:25 AM
TakmaN
Aug 8, 2015 07:47 PM
