Akebono brake pad replacement
Old Aug 1, 2014 | 06:00 PM
Glenn2008's Avatar
Glenn2008
The local Infiniti dealership is running a special on brake replacement. $229/axle to replace pads and turn rotors. New pads/rotor $399./axle. Is this a good price?
Old Aug 1, 2014 | 07:04 PM
Pads cost about $50 and the rest of the $229 is labor, so $179 left for labor is high to me, but I DIY my brakes so it's probably in the ballpark of a fair price. An additional $170 for new rotors is also not outrageous. If you can't or don't want to DIY it's not unreasonable IMO. Be sure it includes a full fluid change (it should but never hurts to double check).
Old Aug 1, 2014 | 08:25 PM
warped ideas's Avatar
warped ideas
A quarter past stripped
My bbk cost me $1800. Akebonos, pads, stoptech rotors, braided SS lines, shipping.... Take away cost of shipping and brake lines the total cost was $397/wheel. Just some numbers for you to reference. I DIY so no labor.
Old Aug 1, 2014 | 09:42 PM
Glenn2008's Avatar
Glenn2008
Thanks guys, I think I'll diy over the winter. What pads and rotors should I purchase? As long as I'm doing this I might as well replace the lines to SS also.
Old Aug 1, 2014 | 10:32 PM
warped ideas
I used a complete kit from Concept Z Performance. They have an "a la carte" kit for our G's. You can pick and choose the equipment you want to buy. I used StopTech slotted rotors and NISMO pads. The SS brake lines are an option as well as every other part of the kit. The base kit will run you around $1500 if I remember right.
Old Aug 2, 2014 | 04:58 PM
Glenn2008's Avatar
Glenn2008
I have judder/vibration when I brake. I'm thinking that the rotors are warped. If I were to purchase the Stop Tech slotted rotors, this probably would go away. The rotors were turned and new pads 12K miles ago at the dealer.
Old Aug 2, 2014 | 06:42 PM
BallyB37's Avatar
BallyB37
Anyone have a link to a site where you can buy OEM pads and rotors? Most links on old posts are now expired.
Old Aug 2, 2014 | 08:02 PM
Glenn2008's Avatar
Glenn2008
^Have you had problems with the oem brakes? I believe that several people have, that's why they have gone to aftermarket rotors. There are several online Infiniti parts sites, just Google them and you see. One I believe is InfinitiUSA
Old Aug 2, 2014 | 10:46 PM
warped ideas
I was abusing my driving privilege and warped my rotors. I had 55K miles on my car and the dealership couldn't turn the rotors due to them being to thin. I then decided to go with the BBK from Concept Z Performance. Check out their web site. They have reasonable prices.
Old Aug 3, 2014 | 06:13 PM
BallyB37's Avatar
BallyB37
Thanks and will do, Any issues with their brakes? (squeal/wear)
Old Aug 3, 2014 | 06:34 PM
warped ideas
A little squeel in reverse for the first month or so. I haven't heard a peep out of them since. I have heard others say the same about slotted rotors before so I don't think it was an issue.
SBG37
Mar 12, 2021 03:16 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
ck1109
Oct 20, 2015 03:34 PM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
zero260
Aug 12, 2015 10:02 AM
