BC Coil Over Clunking Sounds
Old Aug 14, 2014 | 05:02 PM
san~man's Avatar
san~man
Originally Posted by SwissCheeseHead
ummm...it has everything to do with the quality of the coilovers. Yes, an install can always go bad and can attribute to clunking, however even a properly installed BC coilover can clunk. A good coilover (KW, Tanabe, Tein) does not clunk.
OP sell them and get something better.
Don't mean to start a fight, but how the hell can you call Tanabe a "good" c/o? There's so many horror stories about blown struts (after very low mileage) and Tanabe not warranting them it's crazy.
Old Aug 14, 2014 | 05:36 PM
You speak truth sir. I think have the only set of G37 Tanabe's ever sold to NOT have problems. The ones for this application are not up to par with their usual offerings in the past and they have been bad about denying any warranty claims on them when they leak.
Old Aug 21, 2014 | 07:54 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Just an update on this. I changed my rear springs out from 12K to 20K (BC GTR Coilover rear spring) and the height is now perfect for me. Oh, this was lowered from the heighest setting also for the vert (due to the weight).The damping was adjusted from the stiffest to 4 clicks from the stiffest setting. No noises also.
Old Aug 21, 2014 | 11:46 PM
How's the ride w/ the stiffer spring rate, seems like it would be pretty jarring.
Glad you're noise free
Old Aug 22, 2014 | 08:15 AM
cereal2k's Avatar
cereal2k
It's perfect now for the vert. I'm not bottoming out on big dips and the damping is working fine.
Old Apr 6, 2024 | 03:49 PM
Tommy Le's Avatar
Tommy Le
Originally Posted by inknartg37
I've finally had enough and can't stand the obnoxious sound from the rears clunking all day every day. Really takes the luxury out of the car.
Someone stated that there should be a rubber spring buffer in the rear? Was this supposed to come with the springs? Or do you trim down the one from the old ones and put it on top?
Anyone tried this?
have you found the fix to this im having same problem?
parkern
Oct 5, 2015 12:12 PM
G37sPhoton
Oct 4, 2015 11:08 PM
parkern
Oct 1, 2015 10:15 PM
Murkr
Sep 28, 2015 10:45 AM
VQCrew
Sep 26, 2015 01:19 PM
