Lowering options
Old Apr 2, 2014 | 08:46 AM
828's Avatar
828
do you guy have the part number for the swifts?
Old Apr 2, 2014 | 08:54 AM
Swift Springs USA
For the AWD Sedan: 4N907 - That's for the G37x and the G37xS
For the RWD Sedan: 4N908 - That's for the G37, G37S and the 6MT
Old Apr 2, 2014 | 10:42 AM
grojas112's Avatar
grojas112
I contacted Fortune Auto regarding coilovers for the X. This was the response Chris from Fortune Auto gave me.
At the moment we do not have a G37X application, but we will be developing them shortly. We dont have any solid numbers as far as adjustment range.
Old Apr 2, 2014 | 11:10 AM
original sin's Avatar
original sin
Subscribed.
Lisa, could you do a follow up in a week or so on whether your springs settled more or not in the back.
Does anyone have ideas on camber numbers after a swift or eibach spring install and whether camber arms (or toe bolts) are needed?
Old Apr 2, 2014 | 11:19 AM
connoisseurr's Avatar
connoisseurr
The group buy is to help them begin the development for the 37X application. In all honesty, these will be the best option us X guys have for coilovers, I can guarantee that.
Originally Posted by original sin
Subscribed.
Swift springs won't settle much, if any. I think mine may dropped 1/16" if that. I measured close to the same amount of drop as I did on install day. I was able to get an alignment and keep everything in spec. If you wen't with an H&R or an Eibach product, I'd recommend a camber kit.
Old Apr 2, 2014 | 11:35 AM
lisavaccz's Avatar
lisavaccz
absolutely i will be posting an updated picture in a week.. if anyone has ran h&r or eibach with the X sedan please post up some pictures because from what im hearing from the manufactors its not suggested at all
Old Apr 2, 2014 | 11:36 AM
rks's Avatar
rks
Swift Springs USA
come on man, just do it. come to the lowside.
If I lived closer I'd come over with the spring compressors myself.
Old Apr 2, 2014 | 11:42 AM
lisavaccz's Avatar
lisavaccz
just took a break from work to go snap these pictures..
front:
rear: https://mail-attachment.googleuserco...tOWTyWLpktcEP4
Old Apr 2, 2014 | 11:48 AM
socketz67's Avatar
socketz67
Community Builder
Originally Posted by dragion
As I mentioned before, the Swifts are linear and won't be settling much but give the rubber bushings time to compress for about a week and then see.
Mine look pretty level from front to back...
I love the look dragion. Are you running 20mm spacers all around as well? It seems that Swift is the best route to take for anyone that doesn't want the car to look obviously lowered. This is the way the car should have looked stock.
Old Apr 4, 2014 | 10:14 PM
Bota36's Avatar
Bota36
Originally Posted by lisavaccz
yeah my part number is correct. so no one really knows. were giving it a week and going from there. everyone looks so great dropped on swifts though... im so upset
Lisavaccz, I'm sorry you had a bad experience. I hope all gets taken care of because your G looks great. And like others have mentioned, the springs won't settle but the rubber bushings will compress a 16th of an inch, at most.
Old Apr 5, 2014 | 05:52 AM
original sin
What camber specs did you get with the swift springs?
Old Apr 5, 2014 | 07:25 AM
connoisseurr has Swift springs for the AWD, but research on Swift springs for the RWD have led me to expect -1.1 degrees.
Old Apr 5, 2014 | 08:30 AM
ANMVQ's Avatar
ANMVQ
So looks like the swifts are a good choice isle you want just a mild drop.
Any thoughts on putting these on the stock shocks and struts @60k?
Nice Dragion glad to we another MA modded sedan
Old Apr 5, 2014 | 08:40 AM
  #29
Any time you lower the car with aftermarket springs, you compromise the lifetime wear of OEM struts and end links. So either you replace things as needed when needed, or you install CO's and stronger, adjustable aftermarket end links. It just is what it is... I wouldn't obsess over it, because nothing is going to wear overtly right away.
That's my rationale, and I'm sticking to it.
Old Apr 5, 2014 | 08:53 AM
  #30
ANMVQ's Avatar
ANMVQ
Thanx Rochester , endlinks are new ( replaced them already ) was just a little worried about the shocks ECT, even if I only get the summer out if then that's fine with me .
