Swift Spring Install
Old Jan 19, 2014 | 10:30 AM
Kampuchea_G's Avatar
Kampuchea_G
No don't switch to taller sidewalls, you really need to keep your diameter close to OEM size, the 275/30/20s are the proper diameter for that 275 width, going to a 40 or 50 would bring all sorts of issues to your traction control, ABS, and your speedometer would be way off. Post a pic of your whole car for a better reference if you don't mind.
Old Jan 19, 2014 | 10:55 AM
That looks real nice & even, some lowering springs drop the rear of the car too much and you getting "sagging-****" syndrom. I would be very happy w/ that drop. Do you have a measurement from the bottom of the ground to the top of the rear fender edge?
Old Jan 19, 2014 | 10:59 AM
Kampuchea_G
Thanks, I haven't measured it yet though. I just thought it'd be slightly lower compared to others I've seen here with swift springs.
Old Jan 19, 2014 | 04:35 PM
Kampuchea_G
Originally Posted by Bota36
Blnewt is correct. You need to stay with the 275/30/20 as it's close to OEM. Measure with a yard stick from ground to the top of the wheel well. You should be at or around 27" for front and back. If not, you may have had the springs installed incorrectly.
Ok, just measured and I'm pretty much right at 27" all around. Guess it's just me then.
Old Jan 20, 2014 | 10:07 PM
Bota36's Avatar
Bota36
Kampuchea, your G looks great!!! Everyone with the RWD Swifts are running the same drop. By the way, what are your wheel widths and offsets for front and back?
Old Jan 20, 2014 | 11:16 PM
Kampuchea_G
Thanks!! 20x9 with 30 offset and 20x10.5 with 42 offset
G's
Nov 5, 2023 12:01 PM
Ricio1991
Aug 27, 2015 10:17 AM
cparise
Aug 19, 2015 01:51 PM
Dillybar12
Aug 17, 2015 04:52 PM
