Swift Spring Install
Just installed some swift springs for my sedan last night and was wondering how long does it take for them to settle?
Originally Posted by Kampuchea_G
(Post 3723539)
Wait. So after I put on my new wheels and springs, then I need to wait a week before I get an alignment?
I was expecting to get an alignment after the install |
I got an aligment the day after i installed mine. seemed to settle just fine. A week is a good amount tho
It's kind of a general rule to wait several days but YMMV, coilovers don't settle too much, my coils only moved about 1/8" initially and didn't settle any more after a few hours. My springs kept settling a little at a time for the first 4 days and didn't budge after that. I think my springs started about 1/2" higher than where they eventually settled.
If you can safely wait a few days then I would go that route, or if you must get an alignment right away I'd measure your spring height at the fender and if it settles more than 1/4" I'd get the alignment checked again. |
nicee another khmer g!
I waited a week. Car drove fine during that time.
I'm in the same boat. Installed my Swifts Saturday and all tho Swift says no need to wait with there springs I'm waiting until Friday to get it aligned.
Been a week since my install and my back doesn't seem as low as everyone else here I've seen with swift springs. Shouldn't they have settled by now?
Are you on stock wheels? Do you have pictures of drop? The tire profile sometimes makes it look off.
1 Attachment(s)
your on 30 wall so your tires are skinnier than stock
get 40 or 45 to fill it up more |
Originally Posted by malady
(Post 3726416)
get 40 or 45 to fill it up more Ok cool, thanks!! |
(Post 3726417)
Ok cool, thanks!!
Blnewt is correct. You need to stay with the 275/30/20 as it's close to OEM. Measure with a yard stick from ground to the top of the wheel well. You should be at or around 27" for front and back. If not, you may have had the springs installed incorrectly.
