Hearing squeaking
Old Sep 26, 2013 | 10:01 AM
joshk's Avatar
joshk
Hearing squeaking
Hey guys,
What does it mean when my clutch is squeaking when I half clutch it without gas? My breaks are also squeaking so i thought i needed new break pads; when I went to get my oil change they told me both are fine and ended up just lubricating them. The squeaking was gone for a day and I heard it again on my clutch and breaks. Lastly, isn't they dealership suppose to check my tire pressure too when i go in for a oil change? Because the next day after my oil change, my tire pressure lights came on so I get a weird feeling they didn't even check.
Old Sep 26, 2013 | 05:08 PM
Garz's Avatar
Garz
My brakes were squeaking so I purchased new pads. Go to put them on, and there's still a lot of pad left on all of them. Put some grease on the back of the original pads and put them back on. Squeaking went away for a few days and now it's back. It's not bad, so I'm not to worried about it. These thing's just squeak for some people I guess.
Old Sep 26, 2013 | 06:48 PM
JSolo's Avatar
JSolo
Just say no!!!!!
There was a thread on here from Rochester. IIRC, he found the squeak to be a result of the parking brake.
What is a half clutch?
Old Sep 26, 2013 | 07:21 PM
TakmaN's Avatar
TakmaN
Might need to lube up some parts of the clutch pedal? Or does the squeaking sound like it's coming from the transmission itself?
My brakes squeak, the dealer heard me driving in and said, "oh you must have an S huh. They all do that."
Funny thing is that my brakes squeak in reverse and not so much when I'm stopping when going forward. Oh well, I've learned to live with it as long as my brakes work.
Old Sep 27, 2013 | 11:26 AM
joshk's Avatar
joshk
YES.. It is the same with me in regards to squeaking only when i revserve
Old Sep 27, 2013 | 11:27 AM
joshk's Avatar
joshk
Also they told me my tire pressures are fine except the fact that i got a flat tire this morning.. smh
Old Sep 27, 2013 | 08:23 PM
rmfnla's Avatar
rmfnla
All brake squeak comes from vibrating pads.
Grease can help but it has to be hi-temp; the best solution is antip-friction pads available at most auto parts stores.
I remember chasing clutch squeaks years ago in various cars; pedal bearings are often to blame...
parkern
Oct 1, 2015 10:15 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
timc00k
Sep 25, 2015 12:35 PM
T_Buckets_223
Sep 8, 2015 09:49 PM
