Alignment woes.....
Old Sep 14, 2013 | 12:57 AM
  #31
Topher9425's Avatar
Topher9425
I doThink I need them lol...
Old Sep 14, 2013 | 08:35 AM
  #32
Here you go~
Z-1 Performance Automotive Services Inc. - SPL Rear Toe Bolt Lockout Kit 350Z/G35/370Z/G37
Old Sep 14, 2013 | 10:55 AM
  #33
Topher9425's Avatar
Topher9425
Yep, saw those last night.......wonder if they will work with SPC camber arms, i wouldnt see why not
Old Sep 15, 2013 | 12:18 AM
  #34
quakerroatmeal's Avatar
quakerroatmeal
My buddy sells em here as well over here.
Lockout Washers
Old Sep 15, 2013 | 02:50 PM
  #35
Topher9425's Avatar
Topher9425
I do have a question....toe arms can be installed on our cars right? I keep hearing about removing the rear spring bucket and replace with a toe arm. Well I use my spring bucket, so now how do I install a toe arm? Lol
Old Sep 15, 2013 | 02:54 PM
  #36
quakerroatmeal
You read right..toe arm replaces the spring bucket. You can only get them if you have true coilover setup.
Old Sep 15, 2013 | 07:11 PM
  #37
Topher9425's Avatar
Topher9425
Then time for my stance coils lol
Old Sep 15, 2013 | 07:56 PM
  #38
quakerroatmeal
I have read around that the "proper" way to adjust the toe is through the toe bolts. And that the ( "toe" arms are a bad idea because they change 2 planes of suspension geometry as they are lengthened, which affects both toe and rear "caster", whereas the toe bolts in the OEM location only change toe as a result of their adjustment. ).
I'd go with the eccentric toe bolts.
Old Sep 15, 2013 | 09:34 PM
  #39
Topher9425's Avatar
Topher9425
Well I have the SPC toe bolts.......but with being low, they do not hold the alignment setting, and flex out of place. so its a constant trip to the alignment rack to put it back into spec.
Old Sep 15, 2013 | 10:14 PM
  #40
Might be worthwhile to contact SPC and see if they have a lockout kit for their bolts. If they do please post up as I have SPC arms and Toe kit and although my alignment has held true I wouldn't mind a bit more protection.
Old Sep 15, 2013 | 10:38 PM
  #41
quakerroatmeal
The link blnewt and I sent you should do the trick. Those toe lockout washers should keep your toe locked in place.
Quoted from another site
What about aftermarket Toe bolts that come with wider range adjustment eccentric washers?
Well, the aftermarket toe bolts on the market utilize a semi circle toe bolt to mount the eccentric washers. They obtain the semi circle by machining a "flat" section out of the bolt in order to have the higher range - eccentric washer slip over the bolt. This is where the bolt is weakend and becomes the reason why the aftermarket toe bolts out on there begin to SLIP and STRETCH when load is applied.
Old Sep 16, 2013 | 05:05 AM
  #42
Topher9425's Avatar
Topher9425
I understand the lock out bolts, but my question is, with ninth we way to adjust the toe, how are these useful with those of us without toe arms? Pretty much, how can you adjust the toe, with a square bolt locked in between the groves around the edges? Or am I missing some other concept here? Lol
Old Sep 16, 2013 | 08:47 AM
  #43
I think rather than having a complete 360 degree concentric adjustment you'd only be able to adjust in 90 degree segments, so only 4 settings, unless I too am missing something
Old Sep 16, 2013 | 05:28 PM
  #44
quakerroatmeal
Ok I talked to a buddy of mines who I call the suspension guru. Anyways I was wrong about the lockout washers. They ONLY work in conjunction with toe arms. Which means true coils..
Other alternative option is to take your spc toe kit to a machine shop and have them machine you new eccentrics. Read here more about it
MY350Z.COM Forums - View Single Post - Any other toe bolts out there besides SPC?
Another option is to buy the SPL titanium rear mid link. Which is insanely expensive.
Pretty much three choices
1. True coils with lockout washers + toe arms (which he say is the best)
2. Have shop custom machine you new eccentrics (cheapest option)
3. Buy those SPL titanium rear mid link to have complete control over toe (most expensive it seems)
Old Sep 16, 2013 | 07:46 PM
  #45
Topher9425's Avatar
Topher9425
Speaking of true coils......Are Stance GR+ (Stance SS) true coils in the rear? Planning on buying a set, and damn google images shows both for our cars. lol
